When working with a Previs scene the Composition preview may show content with a strange aspect ratio; this is not a bug but rather a technical limitation. This is due to the Render Order, at the point of previewing the Composition the engine doesn't know the design size set by the canvas. It will fall back to the Aspect Ratio set in the Project Properties window.
This shows the currently active physical outputs configured in your Device Configuration. Use this to see what a single output will look like when played out in a Runtime. Inputs can be also previewed if configured inside your Device Configuration.
Enable all Physical Outputs: Will use all physical screens currently configured as outputs inside your Device Configuration and render your scene on it.
Preview at System SDR Level: When HDR mode on: Sets the SDR white-level of the preview renderer to the Windows SDR level of the Windows Display Settings.
Configuration of both Inputs and Outputs can be done inside the Device Configuration.
