« Previous: 3D Layers
Next: Composition Layer »
3D Layer Reference
  1. Properties
  2. Limitations
  3. Common Layer Properties
    1. Blending
      1. Mode
      2. Opacity
      3. Blocked
      4. BlockedOnFullTransparency
      5. Layer Mask
        1. Mask
          1. Texture Loader
          2. Texture Property
          3. 1D Gradient
          4. SVG Loader and SVG Text
        2. Mask Properties
        3. Mask Vignette
        4. Mask Border
  4. Layout
  5. Mapping
  6. Effects
    1. Blending
    2. Mask
    3. Effect
      1. Effect Group
      2. Color Correction
      3. Filters
      4. Distortion
    4. Layer
3D ReferenceThis Layer Renders another 3D Layer a second time, but with the possibility to use another Layout, Camera, IPP Effects, Mask etc.
Properties
Limitations
Blending
Blend Modes
Mode
Opacity
Blocked
Layer Mask
Mask
Texture Source
Texture Loader
Texture Loader Presets
Image/Texture
Description
Internal resource name
Image/Texture
Description
Shape Circle
Shape Triangle
Shape Pentagon
Shape Cross
Spike Star
Checker
internal://images/checker.png
Checker Blue
Checker Dots
internal://images/dots.png
Lines
internal://images/lines.png
Noise
internal://images/noise.png
Alpha Glow Full
Alpha Glow Half-Full
Alpha Glow
Alpha Glow Half-Sharp
Alpha Glow Sharp
Square Blur Sharp
Square Blur Sharp
Square Blur Medium
45 Degree
Linear In/Out
Linear
internal://Images/linear.png
Dimple
internal://images/dimple.png
Pimple
internal://images/pimple.png
Liquid
internal://images/liquid.png
Woodchip
Image/Texture
Description
Image/Texture
Description
Lensflare Ghost Colors
Lensflare Star
Lensflare Dirt
Image/Texture
Description
Image/Texture
Description
Incidence 1D Lambert
Incidence 1D Rainbow
Incidence 1D Specular
Incidence 2D Smooth
Incidence 2D Steps
Incidence Diffuse
Incidence Diffuse Anisotropy
Incidence Specular
Incidence Blue Back
Celshading Steps
Image/Texture
Description
Image/Texture
Description
Hatch Lines
Hatch Curves
Hatch Letters
Texture Property
1D Gradient
Gradient Presets
Image/Texture
Description
String representation
Image/Texture
Description
B/W Ramp
White Alpha Ramp
Black Alpha Ramp
White Highlight
B/W Reflection
B/W Reflection 2
Cholor Chrome
Color Hard Edge
Cholor Spectrum
Color Ramp
Alpha Ramp
A;a0:(1);a1:(0)
Alpha In/Out
A;a0:(0);a0.5:(1);a1:(0)
Alpha Biased In/Out
A;a0:(0);a0.25:(1);a1:(0)
Alpha Bars
SVG Loader Presets
Image/Texture
Description
Ventuz Logo SVG
internal://images/ventuz.svg
Mask Properties
Mask Vignette
Mask Border
Layout
Mapping
Effects
Blending
Mask
Effect
Effect Group
Color Correction
Filters
Distortion
Layer
  • 3D Layer Reference Filter Node
