« Previous: Sphere
Next: Cone »
Cylinder
Cylinder This node provides a cylinder (and tube) geometry.
This is a Geometry Renderer which has a Property Group to switch between different kinds of Geometries. It is also possible to extract the Property Group and make use of it inside the Content Editor. The Cylinder provides a Geometry with adjustable dimensions and, optionally, a hole if the Hole property is set to a non-zero value. The cylinder will be provided for the Geometry Renderer. By decreasing the Angle property, partial cylinders or pie wedges can be created. With the CounterClockwise property you can control in which direction the Cylinder is 'opened' via the Angle property.
  • Nodes and Bindings
« Previous: Sphere
Next: Cone »
