« Previous: Light Sources
Next: Convert To Text »
Array Processing
Float Array Fill Fills a float array with a specific numeric value.
Float Array Offset Adds a specific value to every float array entry.
Float Array Analysis Analyses a float array and provides some characteristic values.
Double Array Analysis Analyses a double array and provides some characteristic values.
Integer Array Analysis Analyses a integer array and provides some characteristic values.
String Array Analysis Analyses a string array and provides some characteristic values.
Array Indexer Provides access to individual array elements.
Array Mixer Mixes up individual arrays.
Fill
Offset
Numeric Analysis
Length Length of the array.
ValidLength Number of entries up to the very first NaN value (does not apply for Integer).
Min The minimum value in the array.
Max The maximum value in the array.
HasPositive At least one value is higher than zero.
HasNegative At least one value is lower than zero.
HasZero True if at least one value is zero.
IsNull True if array bound to the Input property is null.
String Analysis
Provides a number of output properties containing useful information about the string array in general.
ValidLength Number of not-null entries.
LastValidIndex Index of the last not-null entry.
Shortest First shortest not-null string.
Longest First longest not-null string.
ShortestIndex Index of the first shortest not-null string.
LongestIndex Index of the first longest not-null string.
ShortestLength Length of the first shortest not-null string.
LongestLength Length of the first longest not-null string.
HasNulls True if at least one string is null.
Array Indexer
The Array Indexer node provides access to individual elements of an array or to a range of elements. This node is the equivalent to the Array node. The type of array and the number of elements which should be accessed have to be specified when the node is dragged to the Content Editor. Using the buttons on the bottom of the Property Editor you can add and remove elements from the array after the creation has been done. Allowed types are the same as in the Array node. The individual array elements are available as output properties (Value_0000 etc.). The NewArray property also provides these values as an Array property. The event Changed is fired if one of the output properties has changed. The input property IndexStart defines at which index in the source array the reading of the elements should begin. If the last elements in the source array are reached and there are not enough elements to fill all outputs of the Array Indexer, the remaining outputs are set to zero.
Array Mixer
The Array Mixer is able to perform Insert, Remove and Overwrite operations on an incoming Array. The type of array which should be modified has to be specified when the node is dragged to the Content Editor. The initial array content, on which the operations are performed, is specified by the BaseArray property. AutoReset specifies if the output property ResultArray should be reset to BaseArray if the scene is loaded. A manual reset can be triggered by the Reset method. Note that all operation are cumulative and change the active array. All further operation are performed on the modified array!
To insert values to the active array one has to specify the InsertArray, the InsertIndex at which the insertion begins and trigger the Insert method. If the insertion index is larger than the length of the current ResultArray, nothing is inserted!
  • Array node
  • Excel Range Array node
  • Chart nodes
