« Previous: Project and Show Management
Next: Communication Protocol Overview »
Web-based Configuration Editor
Web Browser Configuration Editor
The address is as following:
http://IP Address:22404 Via the Web Browser you can access the Configuration Editor directly by entering the IP of the Ventuz machine and the Port
http://localhost:22404 Open the Configuration Editor via your local VMS on your machine
http://192.168.4.25:22404 sample address for the Web Configuration Editor on another machine
  • Launching Designer or Director
  • Project Properties or Maintenance
  • Editing Shaping/Warping within Render Setups
  • Editing Render Setups on touch screen devices is limited
