« Previous: Interaction Rect
Next: Touch Excluder »
Touch Button
Touch Button A simple interaction node for just registering touches.
The Interaction Transformation Nodes are derived from this node and inherit all its properties. It is the basis of all object-based interaction nodes and represents a basic control element in a user interface.
Output Information
  • TouchEnter: The first touch that hovers over the active area of the button triggers this event.
  • TouchBegin: When the movement of the touch has been big enough that the threshold in the Project Properties is exceeded and the node actually starts reacting on the movement, this event is fired.
  • TouchEnd: The node has stopped reacting on the touch movement, usually because all touches have been released.
  • TouchLeave: The last touch has stopped hovering over the active area of the button and moved away.
  • TouchInside: True if at least one touch is hovering (or pressed) over the active area.
  • TouchPressed: True if at least one touch is pressed inside the active area.
  • TouchProcessing: True if the interaction node has started processing. This only is relevant for the derived nodes as the Touch Button does not really do any processing. It only fires the above events.
Input Parameters
  • MultiTouch
