« Previous: 2D Art
Next: System Engineer »
Programming Quick Guide
  1. Ventuz Introduction
  2. Basics
  3. Advanced
This page will give you a quick overview of the most important pages to start programming and use advanced Remoting features.
To start you might want to have a general overview of our Ventuz Software if you havent done it yet. Just walk through the Ventuz Introduction to get a first idea of the software suite.
Basics
Designer&Runtime
C# / VB Scripts
Learn how to use the C# Script node inside the Ventuz Designer.
HLSL Shader
The HLSL Shader node acts as a host for a user-designed shader program written in the High-Level Shading Level.
Reading Data in Ventuz
Gives you an overview of the possible external data integrations in Ventuz.
designerintroductionExternal datalogiclearning designerlogic workflow
Advanced
Designer&Runtime
Ventuz has been designed to be able to encapsulate almost all internal business logic inside a scene or scene tree.
Designer&Runtime
Ventuz 4 - Remoting
RemotingExternal data
Designer&Runtime
Ventuz Video I/O (VIO) API
The Ventuz Video Input Output API, short VIO, allows Ventuz users to program applications that send video streams towards Ventuz.
Designer&Runtime
Ventuz Stream Out API
The Encoded Stream Out outputs provide a simple pipe based streaming protocol to other processes running on the same machine.
Ventuz File Format (VFF)
Ventuz File Format (VFF) is used to store textures and meshes on disk in a simple way, with all the extra features Ventuz needs.
Designer&Runtime
Ventuz API and SDK reference
The Ventuz Extension API enables programmers to extend the functionality of Ventuz Designer and Runtime.
apiprogramming
« Previous: 2D Art
