![]() | Web Browser | An interactive Internet browser that can be used to render HTML or browse the web. |
The Web Browser node renders web pages into a texture so their content can be used inside a Ventuz scene. Since Ventuz 5.3 this is done based on the Chromium Embedded Framework CEF.
The TrackingMode defines which input interaction is sent to the node and is similar to the behaviour within the Interaction Rectangle:
The Web Browser Node collects all interaction data. Even if other rendered objects are in front, the input data is used in the Web Browser.
Chromium Embedded Framework CEF can handle maximum 16 inputs per browser.
Code | Description |
13 | Return |
9 | Tab |
8 | Backspace |
127 | Delete |
27 | Escape |
%TMP%\Ventuz
41 | Custom |
The Web Browser node supports the JavaScript scripting language both as part of the content as well as a means of interaction between Ventuz and the site content. This is done by defining input/output properties, methods and events in the Custom Model editor at the bottom of the Property Editor.
<html> <head> <title>Method Test</title> </head> <body> <script type="text/javascript"> function CalculateSquare() { var result = ventuz.value * ventuz.value; document.write("The square of " + ventuz.value + " is " + result + "<br>"); ventuz.Result(result); } </script> </body> </html>
Example 1:
Example 2:
UP = function() { window.scrollBy(0,-5); } DW = function() { window.scrollBy(0,5); }
Allow sub pixel text rendering | Disables/enables Clear Type. Monochrome scaled text with Clear Type enabled result in colorful edges. |
Allow ventuz:// from external sites | Allows you to reference assets inside a Ventuz Project from web pages outside the project |
Ignore SSL certification errors | Allow HTTPS sites to load even when certification fails |
Audio | Allows you to configure the In and Out Ventuz Ordinals and global browser Volume. Also check the crosspoint section in the Device Config for further information. |
User Agent | Some web sites (like Facebook.com) expect special keys in the user-agent string. The user agent string can be manually adjusted here. See http://www.user-agents.org/index.shtml |
Content Block List | Downloads a filter lists that automatically remove unwanted content from the internet, including annoying adverts and bothersome banners |
