« Previous: Random Points
Next: Geometry Import (Live) »
Mesh Loader
For a discussion on importing non-vzm files (i.e. FBX, OBJ, COLLADA, glTF, ...) see Importing of 3D Geometry and for a list of supported geometry formats and their characteristics go to Supported Formats.
  • Importing of 3D Geometry
