« Previous: Math Effects
Next: Scene Event »
Matrix
  1. Matrix Operation
  2. Vector Transform
Matrix View This node creates a View Matrix from user friendly inputs. Best used with the Camera Node.
Matrix Projection This node creates a Projection Matrix from user friendly inputs. Best used with the Camera Node.
Transformation This node provides a matrix to transform along the X, Y and Z axis, combining the Rotation, Scaling and Translation in a single Node.
The Matrix Nodes provide special types of matrices that can be used as Input Properties for the World Transformation or View and Projection of the Camera. In the following collapsed container you see an overview of the options of Projection and View Matrices.
View and Projection
Projection
Projection simulates the effect of perspective shortening (i.e. objects farther away appear smaller). This is often defined by specifying a view angle (also called field of view). When a more schematic look is required, this can also be an orthogonal instead of a perspective projection which does not have any perspective shortening at all.
Both, Field of View and Orthogonal have Center input properties X and Y that can be used to shift the center of the projection. The projection also specifies the Near and Far planes, who define the Z value of the closest and farthest point that is still rendered as part of the view frustum.
Field of View defines the camera viewing field by the angle between two opposite sides of the viewing frustum. The Fov input property specifies that angle, FovAxis specifies if those are the left and right (horizontal) or the top and bottom (vertical) sides. The angle between the other two sides is automatically calculated based on the Aspect and AspectRelation properties:
  • Relative: The Aspect property is multiplied with the aspect of the render area in the Renderer Window. With the Aspect Property set to 1 a circle will always appear round, independent of the aspect ratio of the render area. The total aspect ratio will be provided in the AspectResult output property.
  • RelativeLayer: Much like Relative, but the Aspect property is multiplied with the aspect of the current layer.
  • Fixed: The Aspect property will directly be used and the ratio of the render area ignored. The AspectResult output property will be equal to the Aspect input property.
If there is no camera node in the scene, Ventuz will use a default projection which is the equivalent of a 45 degrees Field of View projection with the aspect ratio implied by the output resolution set in the Project Properties.
Orthogonal is a special projection that has no perspective shortening at all. It is often used for schematic views or other situations where perspective shortening would be confusing. The Input Properties Width and Height define the width and height of a 3D space volume that will be displayed in the render output. The orthogonal projection basically cuts out this volume straight out of the World/View space and flattens it along the Z-axis.
Matrix can be used to set up or connect a custom projection matrix. A custom matrix could for example be calculated manually or delivered by a third party device.
View
Matrix Operation
Vector Transform
  • Axis nodes
  • Script nodes
Next: Scene Event »
