![]() | HLSL Shader | A customizable HLSL shader implementation. |
float4x4 Ms2Ss : WORLDVIEWPROJECTION; // matrix from Model Space to Clip Space void VS( float3 MsPos : POSITION, out float4 SsPos : SV_Position ) { SsPos = mul(float4(MsPos,1), Ms2Ss); // transform from model space (Ms9 to clip space (Ss) } void PS( out float4 color : SV_Target0 ) { color = float4(1,0,0,1); } technique11 Tech1 { pass pass0 { vertexshader = compile vs_5_0 VS(); pixelshader = compile ps_5_0 PS(); } }
A shader consists of two programs, the vertex and the pixel shader. The vertex shader is executed for each vertex that is rendered and must at least generate a transformed output position. The graphics card uses this output position to transform the primitive that is rendered into a number of fragments. For each fragment, the pixel shader is executed to calculate the final color of the fragment as it is turned into a pixel. In the example above, the vertex position is transformed using the world-view-projection matrix and each fragment is transformed into a solid red pixel regardless of any light or material nodes in the scene.
A shader usually requires a number of values from the hosting application - in this case Ventuz - to operate properly. Even the simple shader in the example above requires the world-view-projection matrix to properly transform a vertex. There are three ways to assign a variable with proper values coming from Ventuz:
A shader addresses a texture via a sampler object. A lot of shader source codes do not contain an explicit texture variable definition but rather rely on the host application to associate the appropriate texture with a specific sampler. In contrast, Ventuz requires a texture variable declaration to create a bindable texture property. The assignment of a texture to a sampler has to be done from within the shader source code during the sampling:
Texture2D tex : register(t0); // define texture SamplerState sam : register(s0); // define sampler // [...] // inside the pixel shader: color = tex.Sample(sam, UV); //sample tex with sam // [...]
Which texture variable is assigned to which stage depends on what the DirectX shader compiler thinks is best. Usually the first texture used in a render pass (e.g. the respective vertex shader and pixel shader) is assigned to stage 1, the second to stage two and so on. To ensure proper interoperability with the standard Texture nodes, a dedicated stage should be assigned to each sampler, especially when multiple textures are used in multiple passes. This is done by adding :register(sx) after the sample definition where x is a 0 for stage1 up to 7 for stage8.
A vertex texture must be sampled with the SampleLevel function. This is because mipmapping information cannot be computed automatically and must be specified manually. Usually you will want a mipmap LoD of 0.
// [...] float2 uv = input.uv; float lod = 0; float4 tex = tex.SampleLevel(Vertex1,uv,lod); // [...]
Filtering works the same as with pixel shader textures.
If multiple passes are required to render the same geometry, the respective nodes should be linked to both outputs (using CTRL + SHIFT while dragging, see Hierarchy Editor). This avoids creating two copies of all the nodes in the subtree, but there is still a memory overhead compared to using the content only on one output.
One of the biggest drawback of shader semantics is the fact that they are not standardized. It is up to the application to define a string that is used to describe a certain semantic and many applications use incompatible definitions. At the time of writing, Ventuz only supports the following semantics:
Semantic | Type | Description |
WORLD | float4x4 | The object-to-world matrix at the geometry currently rendered. Usually the result of a number of Axis nodes. |
WORLDINVERSE | float4x4 | Inverse of the object-to-world matrix. |
VIEW | float4x4 | The world-to-view matrix at the geometry currently rendered. Usually the result of a Camera node. |
VIEWINVERSE | float4x4 | Inverse of the world-to-view matrix. |
PROJECTION | float4x4 | The view-to-clip space matrix at the geometry currently rendered. Usually the result of a Camera node. |
PROJECTIONINVERSE | float4x4 | Inverse of the view-to-clip space matrix. |
WORLDVIEWPROJECTION | float4x4 | Combined matrix that contains the complete transformation from object to clip space. This is usually used to compute the output position of a vertex. |
WORLDVIEWPROJECTIONINVERSE | float4x4 | Inverse of the world-view-projection matrix. |
WORLDVIEW | float4x4 | Combined matrix that contains the object-view transformation. |
WORLDVIEWINVERSE | float4x4 | Inverse of the world-view matrix. |
VIEWPROJECTION | float4x4 | Combined matrix that contains the transformation from world to clip space. |
VIEWPROJECTIONINVERSE | float4x4 | Inverse of the view-projection matrix. |
Example:
Annotations are an effort by Microsoft to address the disadvantages of using semantics. There are two different categories of annotations: User interface and data binding annotations. All annotations are specified by variable declarations inside less and greater than characters right after the original variable.
float4x4 View < string SasBindAddress = "Sas.Camera.WorldToView"; >;
Sas.Skeleton.MeshToJointToWorld[0] | float4x4 | Object-to-world matrix. |
Sas.Camera.WorldToView | float4x4 | World-to-view matrix. |
Sas.Camera.Projection | float4x4 | View-to-clip space matrix. |
Sas.Light[0].Direction | float3 | Direction vector of the first light source. Indices 0-7 are supported. |
Ventuz.Lights.Ambient | float4 | Ambient color of the most recently set light source with respect to the rendering order of the scene hierarchy. |
Ventuz.Lights.Diffuse | float4 | Diffuse color of the most recently set light source with respect to the rendering order of the scene hierarchy. |
Ventuz.Lights.Direction | float3 | Direction vector of the most recently set light source with respect to the rendering order of the scene hierarchy. |
Ventuz.Lights.Position | float3 | Position of the most recently set light source with respect to the rendering order of the scene hierarchy. |
Ventuz.Lights.Specular | float4 | Specular color of the most recently set light source with respect to the rendering order of the scene hierarchy. |
Ventuz.Material.Alpha | float | Alpha value at the geometry currently rendered. Multiple Alpha nodes or Material nodes may have contributed to this value based on their AlphaRelation properties. |
Ventuz.Material.Ambient | float4 | Ambient material color active at the time the geometry is rendered, usually the result of a parent Material node. |
Ventuz.Material.Color | float4 | Color active at the time the geometry is rendered. In case the geometry is influenced by a Material node, this will be the diffuse color of that node. In case the geometry is influenced by a Color node, this will be the color of that node. Note that the alpha value may be the accumulated alpha of multiple nodes based on the AlphaRelation property of the material node. |
Ventuz.Material.Base | float4 | Base Color. |
Ventuz.Material.Diffuse | float4 | Diffuse material color active at the time the geometry is rendered, usually the result of a parent Material node. Note that the alpha value may be the accumulated alpha of multiple nodes based on the AlphaRelation property of the material node. |
Ventuz.Material.Emissive | float4 | Emissive material color active at the time the geometry is rendered, usually the result of a parent Material node. |
Ventuz.Material.Sharpness | float | Specular material exponent active at the time the geometry is rendered, usually the result of a parent Material node. |
Ventuz.Material.Specular | float4 | Specular material color active at the time the geometry is rendered, usually the result of a parent Material node. |
Ventuz.RenderTarget.Size | float2 | Dimension in pixel of the Offscreen Layer active during rendering of the geometry. |
Ventuz.Texture.Active | bool | True if at least one texture is set to any of the texture stages, usually the result of a parent Texture node. |
Ventuz.Texture.Mapping | float4x4 | Texture mapping matrix active at the time the geometry is rendered, usually the result of a inside a Material node. A shader that wants to respect texture mapping should multiply the input texture coordinates by this matrix to apply the mapping transformation. |
Ventuz.Viewport.Size | float2 | Dimension in pixel of the [NodeLayer3D 3D Layer] active at the time the geometry is rendered. |
Ventuz.DirectionalLight[*] | VentuzDirectionalLight[8] | All directional lights, see Light Source Information |
Ventuz.PointLight[*] | VentuzPointLight[8] | All point-lights, see Light Source Information |
Ventuz.SpotLight[*] | VentuzSpotLight[8] | All spot-lights, see Light Source Information |
Ventuz.Light[*] | VentuzLight[8] | All lights, see Light Source Information |
Ventuz.NumDirectionalLights | int | Number of directional lights |
Ventuz.NumPointLights | int | Number of point-lights |
Ventuz.NumSpotLights | int | Number of spot-lights |
Ventuz.NumLights | int | Number of lights, independent of type |
Ventuz.Textures[*].Size | float4[8] | Size of the texture image in pixels, see Texture Information |
Ventuz.Textures[*].Mapping | float4x4[8] | Mapping matrices for all textures, see Texture Information |
Ventuz.Textures[*].Info | uint4[8] | Information about texture shading and UV mapping, see Texture Information |
Ventuz.NumTextures | int | Number of textures. Exactly: Index of the last used texture stage plus one. |
float4 DiffColor < string SasUiControl = "ColorPicker"; string SasUiLabel = "Diffuse"; > = { 1.0f, 0.022f, 0.0f, 1.0f };
Annotation | Type | Description |
SasUiControl | string | Supported values are ColorPicker and Direction. |
SasUiLabel | string | Name of the property as it will appear in the Property Editor, must be unique with respect to the other properties generated. If the same name is used for different properties, the automatic property generation algorithm will most likely fail or produce incorrect results. |
SasUiMin | int/float | Minimum value for a float or int variable, not supported for vector types. |
SasUiMax | int/float | Maximum value for a float or int variable, not supported for vector types. |
SasUiSteps | int/float | Increments by which a property can be increased/decreased. Can for example be used to only allow odd numbers. |
SasUiVisible | bool | If set to false, no property will be generated for this variable. |
VentuzFavored | bool | By default, all parameters will produce a favored property. Use this annotation to specify whether a property should be favored or not. |
HLSL allows adding state change information to a pass (see MSDN: Effect states. While one could also use the respective Ventuz nodes, it is a convenient way to influence the rendering behavior.
DepthStencilState NoZTest { DepthEnable = FALSE; }; technique11 Tech1 { pass pass0 { vertexshader = compile vs_5_0 VS(); pixelshader = compile ps_5_0 PS(); SetDepthStencilState( NoZTest, 0 ); } }
The state changes are applied when rendering of the respective pass starts, so at the time of the shader node in the rendering order. Any relevant node (for example Z-Testing for DepthEnable) before the shader is overwritten and any node after the shader will overwrite the shader's state change.
Information about all light source can be retrieved in the shader by using the Ventuz.DirectionalLight[*], Ventuz.PointLight[*], Ventuz.SpotLight[*] and Ventuz.Light[*] annotations. First you have to declare the following structures:
struct VentuzDirectionalLight { float3 DiffuseColor; float3 SpecularColor; float3 AmbientColor; float3 Direction; }; struct VentuzPointLight { float3 DiffuseColor; float3 SpecularColor; float3 AmbientColor; float3 Position; float3 Attenuation; float Range; }; struct VentuzSpotLight { float3 DiffuseColor; float3 SpecularColor; float3 AmbientColor; float3 Position; float3 Direction; float3 Attenuation; float4 RangeFallofInnerOuter; }; struct VentuzLight { int Type; float3 DiffuseColor; float3 SpecularColor; float3 AmbientColor; float3 Position; float3 Direction; float3 Attenuation; float4 RangeFallofInnerOuter; };
VentuzDirectionalLight DirLights[8] < string SasBindAddress = "Ventuz.DirectionalLight[*]"; >; VentuzPointLight PointLights[8] < string SasBindAddress = "Ventuz.PointLight[*]"; >; VentuzSpotLight SpotLights[8] < string SasBindAddress = "Ventuz.SpotLight[*]"; >; VentuzLight SpotLights[8] < string SasBindAddress = "Ventuz.Light[*]"; >; int DirectionalLightCount < string SasBindAddress = "Ventuz.NumDirectionalLights"; >; int PointLightCount < string SasBindAddress = "Ventuz.NumPointLights"; >; int SpotLightCount < string SasBindAddress = "Ventuz.NumSpotLights"; >; int LightCount < string SasBindAddress = "Ventuz.NumLights"; >;
Note that the old DX9 Attenuation values are not used anymore and set to 0 since Ventuz 7.
The field RangeFallofInnerOuter holds for information:
The light Type is:
float4 TexSize[8] < string SasBindAddress = "Ventuz.Textures[*].Size"; >; float4x4 TexMap[8] < string SasBindAddress = "Ventuz.Textures[*].Mapping"; >; uint4 TexInfo[8] < string SasBindAddress = "Ventuz.Textures[*].Info"; >; int TexCount < string SasBindAddress = "Ventuz.NumTextures"; >;
Ventuz.Textures[*].Info contains various information about selected texture options. Most of this information does only work with the old legacy texture node, which has been removed. The only thing that still works is:
The sampling options in info.w are
For a shader to work properly, a certain amount of functionality is required in the hosting application. Since the implementation of that functionality varies from application to application, it is in general not possible to simply copy-and-paste the shader source code from another application into Ventuz and having it produce the same results without modifications. The following is a list of points based on the experiences on porting shaders to Ventuz:
