« Previous: System ID
Next: Text Splitter »
Filter
Mirror FilterThis node can restrict which objects are rendered to a Mirror.
Clip Plane FilterThis node can restrict which objects are clipped by a Clip Plane
Cubemap Filter The Cubemap Filter can restrict which objects are rendered to a Cubemap.
Rank Filter The Rank Filter is used in Chroma Keying mode to render parts of the Hierarchy to the Background, Foreground or Garbage Matte.
Shadow Filter Filters Objects for the Shadow Map Rendering.
3D Layer Reference Filter Filters objects for each rendering of a 3D Layer issued by 3D Layer References.
Render Filter Filter specific parts of your rendering on Previsualization Scenes or on Screens used in the Render Setup Editor.
Mirror Filter
Condition Description
Always Rendered and visible in the Mirror
BehindMirror Not rendered but visible in the Mirror
BeforeMirror Rendered but not visible in the Mirror
Clip Plane Filter
Cubemap Filter
Always Rendered and visible inside the reflection
InReflection Not rendered but visible inside the reflection
Outside Rendered but not visible inside the reflection
Rank Filter
Shadow Filter
Render Filter
Use the filter groups to assign specific parts of your rendering to it and ignore others. These groups need to be also set on the Previs Screen node or inside the Render Setup Editor on Screens to fully work. Filter groups are usable from A to H either on the Render Filter node or under the Render Options inside the Previs Screen node. If ignore is chosen all groups set will be ignored.
The set filter group decides what to see when assigning the same group on the Previs Screen! All other groups will be not rendered.
  • Mirror Node
  • Clip Plane Node
  • Render Cubemap Node
  • Shadow from Lightsource
  • Shadow Options
