![]() | 3D Standard | This is a standard 3D Layer |
![]() | 3D HDR | This is a Layer using the High Dynamic Range engine mode |
Ventuz 3D layers have 2 different render engines or modes:
ECC Level
Color Space:
Source:
Target:
This enables the Depth of Field effect, an effect that is often used in filmmaking and uses the blurriness of the out of focus elements in the scene to drive viewer's attention to certain parts of the image. The options are None, Fast Depth of Field and Quality Depth of Field - the latter is available in two versions, one with simple settings and one with advanced settings similar to the Fast Depth of Field. Simple Depth of Field is a relatively fast method of calculating DoF, but it comes with a drawback: The quality is very much dependent on proper settings. At this point in time, it mostly is used in small amounts to add realism to 3D scenes. The Quality Depth of Field uses up more perfomance but is easier to control, especially the non-advanced version of it.
Common Properties:
This lists all properties that are present on all types of Depth of Field shaders:
Instead of an enumeration you can control the Sampling Quality of the Quality Depth of Field using a floating point number between 0 and 1. The effect of the property stays the same.
Quality DoF:
This lists all properties on the simple Quality Depth of Field:
Fast and Quality Advanced DoF:
Following is a list of the common properties of Fast Depth of Field and Quality Depth of Field Advanced:
The term generally refers to the process of removing jagged edges of objects. They may appear because of the limited raster of pixels on the render output. There are several techniques to reduce the aliasing, like Multi Sampling or Fast Approximate Anti Aliasing. For more information see the different sampling methods we support in Ventuz that are explained in detail here.
On the 3D Layer Root, you can change the Anti-Aliasing either to use the configured options of the Device Configuration or to use a dedicated sampling method.
The Depth Keyer can be used to key out certain portions of the rendering of the 3D Layer based on the the depth. This is useful if you need to feed in any kind of image that has no alpha yet you need to composite it in your scene. An example for such images is the texture coming from the Unreal Live Link.
The Depth defines the threshold of this keyer: everything behind this threshold is keyed out, while everything in front is left in the rendering as it is. When Apply to Fill is disabled the keyer applies to the layer's alpha channel only and leaves its color channels as they are. This is useful for Augmented Reality setups with any sorts of external chroma keying. Show offers debug visuals to get an idea of what is happening inside the shader. You can see the resulting Key as well as the scene's depth. Softness, Choke and Edge Softness work in the same way as the according properties on the Color Difference Keyer Layer Effect. When Enable Anti Alias is turned on, the effect will have aliased edges to smooth out the Alpha. With this disabled, the resulting key is either 0 or 1 - an FXAA algorithm is used to fade this smoothly when its enabled. The Fxaa Sub Pixel property changes this algorithm's parameter as described in the Anti Aliasing reference page.
This section describes working with a HDR layer in a SDR workflow, with Rec.709/sRGB as Project Color Space.
With the Engine drop-down menu you can switch to High Dynamic Range. The calculation will then switch internally into a 16bit floating point precision which makes it possible to make proper use of real HDRi's (High Dynamic Range images) and lighting calculation for effects like bloom and glare.
Unfold or Right Click the Engine property to show HDR specific properties. You can adjust the Exposure level then, to change the luminosity level. The Dither option reduces color banding. FrustumCulling works the same way as in the Standard Engine mode.
Another Property group called ToneMapping is now available. In the drop-down menu you can switch between Reinhard, Linear, Filmic and Khronos PBR neutral tonemapping. The default Reinhard tone mapping lets you adjust the Whitepoint which sets the luminance level to use as the upper end of a tone mapping curve. The Whitepoint is mostly adjusted by artists to create a more colorful result. Linear and Filmic have no properties to change since they are based on fixed internal formulas, except for the PreserverAlpha. Linear renders really linear colors from 0 to infinity, while our monitor use colors at gamma around 2.2 from 0 to 1. When using the Filmic tone mapping, it happens that in the real world the Film itself is not capable of capturing the whole intensities, it uses a characteristic curve, it does not capture the intensities linearly. Film tone mapping, therefore, is an artistic tone mapper which emulates the natural film. There is a real advantage when using the Filmic Curve: You have Crisp blacks, a saturated dark end and nice highlights. Khronos PBR neutral tone mapping is designed to keep color accuracy and saturation. (More info: here)
If the Project Color Space is set to a linear space, the properties for tone mapping are disabled, since there is no tone mapping necessary before the blending stage with other layers. The HDR Layer and the layer blending calculates in 16-bit float. See HDR in Ventuz for more general information, the How To Use the HDR Layer and for playing out an HDR signal: How To Enable HDR output
