Rectangle | A flat, rectangle shaped mesh primitive. By far the most frequently used geometry in a typical Ventuz scene. | |
Rounded Rectangle | Similar to Rectangle but each corner individually can be made either rounded or sharp. | |
Gradient Rectangle | Similar to Rectangle but can be assigned two color values to create a resolution independent gradient. |
All here listed Rectangle types, except the Gradient Rectangle, will provide their geometry for the Geometry Renderer. The differences for each Rectangle type can be found in the following sections.
