When working with nested scenes and remoting, one can easily lose one's overview of which scene is rendered where. That is why Ventuz provides the Scene Tree (SHIFT-F12):
This editor shows all scenes in memory along with their available ports. Scenes can be loaded by Ventuz Designer, by a Port node or by Remoting. The editor uses a tree-like visualization similar to that used in the Hierarchy Editor. Drag&Drop makes it easy to assign scenes to Ports and track assignment changes via Remoting. The scenes currently opened in the Designer as well as the current Layout scene are visually marked in the Scene Tree Editor. The screen-shot above shows following situation:
Whenever a scene is loaded by one of our available Remote Interfaces or through the Template Engine, the Scene is marked by a red dot. Those scenes are always kept in memory until either the remote program is unloading the scene or the clean up button is pressed.
With Ventuz 7 and the introduction of Compositions the Layout Scene technically needs a Composition. If you dont add a Composition to the Layout Scene, Ventuz will automatically creates a Default Composition. This will ensure, that the loaded scenes are usable with the default Rendersetup or a custom Render Setup with the default composition. If you create a Layout Scene with Compositions and Scene Layer in it, Ventuz wont add automatically a Default Composition.
With creating a Layout Scene with multiple Compositions, each containing a Scene Layer, the Render Setup enables you to flexible layout and map your rendering. The arrangment of your scenes in the Layer Ports is therefore later flexible changeable. Especially, when you are using the Channels of the Director to control the loaded content, this is very powerful. The final layout of the production is not needed to know when creating the Layout Scene.
A Layout setup is created by clicking the New button. In the General tab, a name for the Layout and the actual Layout scene file can be chosen. The fields Description and Icon can be used to help other users who work on the same project.
The Machine Tags property is a list of comma-separated three-character-codes. They are used to determine which Layout will be used on the current machine. Each machine has a Machine Tag that is defined in its Ventuz Configuration. Once the Runtime is started it will search for that tag in the Layouts - if no tag is given or it is not present in any Layout, the default layout will be used: Every entry in the Layout list has a check-box. The checked Layout is selected as the Runtime Layout which is automatically used if a scene is exported as Presentation (VPR) or the Ventuz Runtime is started in Director mode and no tagged Layout is used.
Interfacing allows for communication between Layout scenes and the inner scenes loaded via the corresponding Port Nodes. The properties which should be used for the inter-scene communication have to be exposed on Layer level. To create the interface counterpart on Layout scene level, an inner scene with the appropriate exposings has to be loaded to a Port.
