Web Browser | An interactive Internet browser that can be used to render HTML or browse the web. |
The Web Browser node renders web pages into a texture so their content can be used inside a Ventuz scene. Since Ventuz 5.3 this is done based on the Chromium Embedded Framework CEF.
Chromium Embedded Framework CEF can handle maximum 16 inputs per browser.
Code | Description |
13 | Return |
9 | Tab |
8 | Backspace |
127 | Delete |
27 | Escape |
%TMP%\Ventuz
41 | Custom |
The Web Browser node supports the JavaScript scripting language both as part of the content as well as a means of interaction between Ventuz and the site content. This is done by defining input/output properties, methods and events in the Custom Model editor at the bottom of the Property Editor.
<html> <head> <title>Method Test</title> </head> <body> <script type="text/javascript"> function CalculateSquare() { var result = ventuz.value * ventuz.value; document.write("The square of " + ventuz.value + " is " + result + "<br>"); ventuz.Result(result); } </script> </body> </html>
Example 1:
Example 2:
UP = function() { window.scrollBy(0,-5); } DW = function() { window.scrollBy(0,5); }
Allow sub pixel text rendering | Disables/enables Clear Type. Monochrome scaled text with Clear Type enabled result in colorful edges. |
Allow ventuz:// from external sites | Allows you to reference assets inside a Ventuz Project from web pages outside the project |
Ignore SSL certification errors | Allow HTTPS sites to load even when certification fails |
Audio | Allows you to configure the In and Out Ventuz Ordinals and global browser Volume. Also check the crosspoint section in the Device Config for further information. |
User Agent | Some web sites (like Facebook.com) expect special keys in the user-agent string. The user agent string can be manually adjusted here. See http://www.user-agents.org/index.shtml |
Content Block List | Downloads a filter lists that automatically remove unwanted content from the internet, including annoying adverts and bothersome banners |
