String Casing | This node sets all input text characters to either upper or lower case letters. | |
String Replace | This node searches and replaces a substring within a text string. | |
String Search | This node searches a substring within a text string. | |
String Trim | This node removes characters from the start and/or end of a text string. | |
String Length | This node provides the number of characters in a text string. |
Note that the String Trim node implements the Trim method of the .NET Sring class.
