New Features as of Ventuz 4.05.00:
When familiar with Ventuz 4 shaping it might be best starting to revisit our updated introduction
Then look at the new features linked here:
You can shape/warp the whole multi-machine Cluster if you select the according group in the Ventuz Configuration Editor and then open the RenderSetup editor!
So to summarize:
Totally disabling shaping is, of course, the fastest.
Soft-edging will impact the speed of Ventuz only a little, and that impact is independent of the number of edges. Only while changing the edges with the editor, recreating the edge-texture might be notable of course.
The output navigation (3) displays a schematic view of the outputs. It will not try to faithfully represent the actual size and position of the displays but indicates the general layout, like a subway map will not represent the actual distance between stations. For instance, overlap is not shown here.
The area marked with (4) can be used to switch between warping and soft-edging. The output section contains color correction and other per-output settings.
These settings will affect the presenter / cluster even after the render setup has been left:
Nr | Name | Description |
1 | Enable warping | If this is disabled, the whole warping engine is disabled |
2 | Enable soft-edging | Disable only soft-edging. Usually one would switch off the edging until warping is done. |
3 | Enable color correction | Disable only color correction. Quickly disabling and re-enabling color correction can be used to check the effect of color correction |
4 | White background | Fill the unused pixels of an output with white instead of black. This shows how many pixels are wasted because of the warping. |
5 | Highlight overlap areas | Sometimes it is useful to highlight the areas where the outputs overlap because precise warping here is especially important. |
6 | Cut soft-edges | This will cut the soft-edges in a way that the output of the two sides directly touch but not overlap. This is useful to check how well the outputs match colors. This requires that the warping has been done already. |
7 | Darken rendering / test image | Sometimes the user interface overlay is hard to see over a bright rendering or test pattern. This button will darken the background to remedy this. |
8 | Solo Mode | Like in an audio mixer, this disables all other outputs. Useful when there is confusion which output contributes to what. Also, the test pattern will center to the solo output. |
9 | 3D-Projection in Editor | Enable / Disable the effect of the 3d projection in the shaping editor. It is a matter of taste what to prefer. 3D-Projection is always enabled on the outputs. |
14 | Show keyboard shortcuts | Most users prefer to do as much as possible with the keyboard alone. This option aids in memorizing the keys. |
15 | Screen GUI options | Control extent and size of the user interface HUD provided on the outputs. |
10 | Enable test pattern | Enable test pattern. In the editor, the test pattern is always shown. The presenter can show either test pattern or the Ventuz scene. |
11 | Multiply output color | Each output is assigned a color. This will multiply the test pattern foreground color with the output color. If good colors are assigned to the outputs, this helps to identify outputs and figure out which of two overlapping outputs needs warping and which is correct. |
12 | Select test pattern | There are many useful test patterns programmed already. If they are insufficient, user images can be used as test patterns. |
13 | Test pattern options | Most test patterns have a range of options to configure the width and distance of lines or the colors. |
Most test patterns offer a foreground and a background color. Also each output can be assigned a color. By pressing the Multiply output color icon in the global toolbar, the foreground color will be multiplied with the output color. For this to work, it is best to choose a bright color as the foreground color.
By default grid and checker test patterns will not perfectly fit, the last row and column will be cut off. By pressing Fit corners, this will be corrected, at the price that the aspect ratio is not guaranteed to be 1:1.
The image test pattern allows you to specify a directory that contains any pictures you prefer as test patterns. It is important that all presenters in a cluster and the computer that runs the shaping editor have the images on the exact same path. Using a network share is the simplest way to ensure this. If the image could not be loaded, a dummy image with color gradients is generated. The files in the directory are filtered for common image file types, like bmp, png, gif, tif, tga and jpg.
To select points, left-click on them. Pressing shift while doing so will add to the selection. When clicking beside the points, a rectangle is drawn as the mouse moves, and the points in the rectangle are selected. Again, pressing shift while doing so will add to the selection.
In addition to the primary control points at the cross-sections of the grid, there are control handles for finer control over the mesh. These are only visible, and can only be clicked on when the associated primary control point is selected.
The control points can be moved with the mouse just as they are selected, that is or + SHIFT. Holding CTRL while moving the mouse will limit the movement to either the x or y axis. This works by pressing CTRL before or after clicking . To move the points with the keyboard, use the Cursor keys + SHIFT.
For a warping layer, there is a way to move a control point without warping the image. This allows to move a point to a feature of the projection screen, and warp from there. With the mouse, use + CTRL. With the keyboard, use Cursor + SHIFT + CTRL. Before doing this, consider using the UV Editor, in most cases, it is more precise and intuitive.
By default, the control points are mapped to evenly spaced locations of the content (or test image). So if you have a 5x5 grid and your test pattern is a 4x4 checkerboard, each control-point is directly bound to one of the intersections:
Mouse | Keyboard | Description |
Cursor | select point | |
SHIFT Cursor | move selected points | |
click on point | select only this point, then move | |
SHIFT click on point | add point to selection, then move | |
CTRL click | move only horizontally or vertically | |
click not on point | B, then Cursor | box selection |
SHIFT ALT click | SHIFT ALT Cursor | smart editing |
CTRL click | CTRL Cursor | move without warping |
| pan | |
| zoom |
Nr. | Keyboard / Mouse | Descriptions |
1 | Insert row (right of cursor) | |
2 | Insert columns (below cursor) | |
3-7 | A U K L S | Handle Modes, see below |
8 | X | Reset selected points to default position |
9 | | Zoom in |
10 | R | Reset zoom and pan |
11 | | Zoom out |
12 | CTRL-Z | Undo |
13 | CTRL-SHIFT-Z or CTRL-Y | Redo |
14 | cycle with O, SHIFT O | Mirror Mode off |
15 | cycle with O | Mirror Mode Horizontal |
16 | cycle with O | Mirror Mode Vertical |
17 | cycle with O | Mirror Mode Horizontal + Vertical |
18 | cycle with O | Mirror Mode Point-Symmetry |
19 | Normal Control Point Movement (Translation) | |
20 | Toggle with SHIFT S | Scale |
21 | Toggle with SHIFT R | Rotation |
22 | Toggle with SHIFT U | UV Edit Mode |
- | ESCAPE | Reset mirror, scale, rotate and multiselect |
Normal | Box Selection | UV Editor | UV Box Selection | |
Translate (default) | ||||
Scale SHIFT S | ||||
Rotate SHIFT R |
Name | Color | Shortcut | Description |
Linked | Green | A | Both sides have same direction and stretching |
Straight | Yellow | U | Both sides have same direction, but can be stretched differently |
Unlinked | Red | K | Both sides are completely independent, allowing for kinks and different stretching |
Linear | Pink | L | Handles are automatically calculated for linear interpolation |
Default | Brown | S | Handles are automatically calculated for maximum smoothness |
With most modes, the change of a handle is local and affects only the area of the surrounding 3x3 control points. In default mode, the change affects a 5x5 surrounding. This mode is useful for the 2x2 and 3x3 layers where this does not matter.
Please note that the handle modes are changed by this action: when inserting a single row into a 5x5 grid, the distances between the rows is different and the linked handle mode can not be used anymore, it is automatically changed to straight where that is required.
By pressing the '+' icon in the layer navigation, the finest layer can be subdivided in X, Y or both. This will insert a row and/or columns between every existing pair of rows/columns: a 5x5 point grid turns into a 9x9 point grid.
As 33x33 is the finest allowed layer, any layer with more than 17 points either horizontally or vertically can not be subdivided anymore.
One can have multiple warp groups per output. They are independent of each other, but share the same color correction and are drawn in the bottom to top order. If the warp groups overlap, use the toolbar or the ALT key and Page Up / Down to change the order. Pressing E will cycle through the groups.
In manual mode, only one edge can be edited at a time.
Gain | For color correction, a value that is used to multiply the rendering pixels |
Lift | For color correction, a value that is added to the rendering pixels, before contrast is applied |
To change all 3 (red, green and blue) sliders at the same time, press the Alt key while dragging with the mouse. This will change the color values while trying to preserve the ratios between the colors, so brown will always stay brown and not become more and more pale-white as values increase.
The Quality section mainly controls how fine the warping mesh is to be tessellated. The defaults are set for quite high quality, when using more precise values you should check for wasteful over-tesselation with the Show Wireframe option.
Max Level | Maximum subdivision when creating the mesh from the finest layer |
Position Error | Acceptable difference for the vertex positions between perfect Beziér interpolation and the actual mesh, in pixels |
Mapping Error | Acceptable difference for the UV mapping between perfect Beziér interpolation and the actual mesh, in pixels |
Ramp Error | Acceptable difference for ramp colors between perfect Beziér interpolation and the actual mesh, in color values ranging from 0 to 255 |
Dither Mode | Enable dithering to improve ramp quality. Temporal dithering will change the dither pattern every frame, that usually gives better results but may result in undesirable artifacts. |
Show Wireframe | Shows the wireframe of the warping mesh. Useful for checking if the level of subdivision is reasonable or insane. |
The Projector Gui Enable button allows excluding some of the outputs from being affected by the shaping editor. Warping, Shaping and Masking are done as edited, but test patterns and the user interface is never drawn. The affected outputs are crossed out in the navigation.
This allows making a warp group use only a portion of the content. Numerical input is possible for entering precise values.
Shift will move the warp mesh
