Value Buffer | This node buffers values until they are needed for further processing. |
Float, Int, Boolean, Byte, String, Matrix, URI and Object.
Whenever a value of an Output changes, the Changed event is fired. In a similar fashion, the Passed event is fired whenever the output changes, either because Pass was triggered or Bypass is active a value changed.
Type | Default |
Float | 0 |
Int | 0 |
Bool | false |
String | null |
Byte | 0 |
Matrix | Zero |
Uri | null |
Object | null |
