Effect | Applies an Image Post Processing Effect to a part of the Hierarchy Tree. |
With the Blending Property you can change how the resulting Texture of the Node should be blended onto the rest of the scene. There are five Blending Modes of which you can choose. The Gain property defines a factor which the texture should be multiplied by before blending.
Resolution changes the size of the used Render Target. This can drastically reduce the impact on the GPU Performance and Memory. Especially with Distortion effects like Blurring you will most of the times not need the full resolution of the Layer. Lastly the AntiAliasing Property Group can adjust the used Anti-Aliasing for the resulting texture.
