Gradient Texture | Generates a 1D Gradient Texture |
You can use the Color Gradient Editor to manually create one with the Gradient property. For each defined key in the Gradient Editor the Node creates a Color and/or Alpha Property respectively. The Values of the keyframes (not their position) can now also be defined through these properties, e.g. by binding them to other nodes.
The Vertical boolean defines the rotation of the gradient.
