Touch Marker | Receiver for unique marker objects such as fiducial, bar-coded objects, and so on. |
Camera based MultiTouch systems often support the recognition of uniquely marked objects. For example, a glass might have a barcode underneath it and when placed on the tracking surface, a special menu shows the user a selection of dishes that go well with exactly this drink.
The interpretation of markers - if supported at all - and which ID corresponds to which pattern is done by the tracking software that comes with the MultiTouch hardware, not Ventuz. Please refer to your hardware's manual to find out more about marker support and what IDs are generated.
A Touch Marker node is bound to a specific touch marker by setting the MarkerID property to the respective ID assigned by the touch hardware. The node will fire events when the marker is placed on the table or lifted from it. It also provides the X/Y position in screen coordinates and the angle of rotation. Unlike the other interaction nodes, the Touch Marker currently has no implicit behavior and therefore only acts as a value provider.
The Touch Marker node is a special node as it is the only node that reacts to marker objects. Marker touches also cannot be used to activate any of the other interaction nodes.
