View | ||
| Scroll vertically | |
Selection | ||
click | Node | Select Node |
SHIFT click | Node | Add Node to selection |
CTRL + Q | Node | Select Siblings |
Visibility | ||
CTRL + R | Node | Toggle Render Point (solo Layer) |
ALT + | Node | Toggle Render Point (solo Layer) |
CTRL + SHIFT + R | selected Nodes | Lock Visibility |
Editing | ||
CTRL + B | selected Nodes | Block selection (disable Eye) |
CTRL + X | selected Nodes | Cut selection to clipboard |
CTRL + C | selected Nodes | Copy selection to clipboard |
CTRL + V | selected Node | Paste from clipboard below |
CTRL + V | no selection | Paste from clipboard |
CTRL + P | selected Nodes | Duplicate selection |
CTRL + SHIFT + P | selected Nodes | Duplicate selection and keep sources |
DELETE | selected Nodes | Delete selection |
SHIFT + DELETE | selected Nodes | Unlink selection |
click | Node | Expand/Collapse children |
CTRL + L | selected Nodes | Expand/Collapse selection |
CTRL + D | Node | Navigate one level down to edit selected Layer |
ENTER | Node | Navigate one level down to edit selected Layer |
click | Node | Navigate one level down to edit selected Layer |
CTRL + U | selected Nodes | Navigate up to layer level |
Naming | ||
double | Node | Edit name |
F2 | selected Node | Edit name |
ENTER | name editing | Confirm name edit |
ESC | name editing | Cancel name edit |
Drag&Drop | ||
drag | selected Nodes | Drag selection |
Drag&Drop Layer Nodes inside the Layer Editor or from Repositories or Toolbox | ||
drop | Drop-Target (orange line) | Copy/Move |
SHIFT drop | Drop-Target (orange line) | Move |
CTRL drop | Drop-Target (orange line) | Copy |
CTRL + ALT drop | Drop-Target (orange line) | Reference Copy |
Drag&Drop Properties or Methods | ||
drop | Node | Show sources popup (Binding) |
hover | Node, Property Group or Category | Un-collapse Layer, Group or Category |
