Template Port | This node provides access to the Template Engine from within the scene logic |
The Template Port Node is only able to properly load a template embedded in a scene with a single 3D Layer. All other layer types are ignored and if there is more than one 3D Layer only the first one will be used and validated.
When the Release property is enabled the loaded Scene will be released in the memory after the Template is taken off air and therefore not needed anymore. Note that it will take some time to load the Scene again on the next take, so you should only use this if you are sure that the Template in that Scene is only used once.
Count indicates the amount of takes available, if no or an invalid Data is set the property shows the default value 0. Current shows the current state of the template -1 means that a template is cueing. Duration provides the duration of the transition from the present template to the next one. Descripton gives the user defined description of the template.
