Ventuz 5 Quick Guide
Ventuz 5 Designer
Ventuz 5 Node Reference
  • Point Options
  • Render Options
  • FFT Audio Analysis
Ventuz 5 Director
  • PropertyGroups
Texture Saver
A new feature is to save the Cubemaps from the Render Cubemap Node as HDRI. You would bind the Output of the Render Cubemap Node and set the filename to "yourfilename.HDR". Your selected resolution will be the size of one face (a cubemap consists of six faces).
  • Snapshot node
  • Image Loader nodes
