![]() | Live Video | This node provides video input from SDI/DVI input cards, webcams, TV tuners, DV device, etc. as a texture. |
![]() | Movie Clip | This node loads movies of many file formats and provides their content as a texture. |
![]() | Movie Frame | This node provides single frames of a movie clip. |
![]() | Movie Stream | This node provides single frames of a movie stream. |
The property Ordinal specifies the device which provides the video frames. The list of these devices can be edited in the Video section of the Audio Video Configuration. The methods Disable and Enable pause and resume the video input stream and shows in pause state either the last frame, black or white depending what you configured in the Board Options . The Live Video Node provides the live video frames in the Texture output property. This one has to be bound to a Texture node.
To read ancillary data from an SDI input, first check Enable Ancillary Input in the Machine Configuration. Then click on Edit Custom Model at the bottom of the properties window of the live video node. This allows to add reading certain kind of information:
Name | Description | Standard | Supported on |
LTC_ | LTC timecode | RP 188 | Deltacast, DVS, Black Magic |
VIT1 | VITC timecode field 1 | RP 188 | Deltacast, DVS, Black Magic |
VIT2 | VITC timecode field 2 | RP 188 | Deltacast, DVS, Black Magic |
AFD_ | Advanced Format Description | SMPTE 2016 | Deltacast, DVS |
AFD Code | Value 4:3 | Description for 4:3 | Value 16:9 | Description for 16:9 |
-/- | -1 | AFD not found | -1 | AFD not found |
0000 | 0 | undefined | 1 | undefined |
0001 | 2 | reserved | 3 | reserved |
0010 | 4 | not recommended | 5 | not recommended |
0011 | 6 | not recommended | 7 | not recommended |
0100 | 8 | letterbox with bar data | 9 | letterbox with bar data |
0101 | 10 | reserved | 11 | Reserved |
0110 | 12 | reserved | 13 | Reserved |
0111 | 14 | reserved | 15 | Reserved |
1000 | 16 | full-frame 4:3, same as coded | 17 | full frame 16:9, same as coded |
1001 | 18 | full-frame 4:3 | 19 | pillarbox 4:3 |
1010 | 20 | letterbox 16:9 | 21 | full-frame 16:9 |
1011 | 22 | letterbox 14:9 | 23 | pillarbox 14:9 |
1100 | 24 | reserved | 25 | reserved |
1101 | 26 | full-frame 4:3 with alternate 14:9 center | 27 | pillarbox 4:3 with alternate 14:9 center |
1110 | 28 | letterbox 16:9 with alternate 14:9 center | 29 | full-frame 16:9 with alternate 14:9 center |
1111 | 30 | letterbox 16:9 with alternate 4:3 center | 31 | full-frame 16:9 with alternate 4:3 center |
bit 9 | bit 8 | bit 7 | bit 6 | bit 5 | bit 4 | bit 3 | bit 2 | bit 1 | bit 0 |
!Parity | Parity | 0 | code3 | code2 | code1 | code0 | Aspect | 0 | 0 |
bit 31..7 | bit 6 | bit 5 | bit 4 | bit 3 | bit 2 | bit 1 | bit 0 |
0..0 | 0 | 0 | code3 | code2 | code1 | code0 | Aspect |
The Movie Clip node gives the Ventuz operator more control over initialization and playback of movie clips. It provides frame accurate playback for use in Ventuz Cluster setups and is able to play the most common video container formats like WMV, AVI, MOV and MKV. Moreover, it is capable of playing Quicktime movies in Ventuz. For all full list of supported video codecs, see Supported Video Formats. The video decoder in this node is based on the FFMPEG project and provides the best performance compared to pre-installed DirectShow and WMF decoders.
Usually, Ventuz will automatically detect color space and range. But some codecs give false information, and some clips are badly encoded. These options allow overriding the automatically detected. When using these options, be careful not to do more harm than good! These options do not apply to RGB encoded clips or images.
Color Space is one of the YUV color spaces. The difference between these is largest for saturated colors, so when in doubt use clips with color bars to check. On normal material the difference is often hard to see.
auto | use automatic detection (recommended) |
BT601 | used by NTSC & PAL |
BT709 | used by modern HD standards |
SMPTE240M | interim specification, replaced by BT709 to which it is similar |
FCC | FCC version of NTSC, basically BT601 rounded to two decimals |
Disable Threading
Enable Audio Compensation
Ignore Clip Duration
Preserve | The node stays in the active state (Play or Pause). |
Play | The node starts playing once seek has completed. |
Pause | The node seeks to the requested frame, displays it and pauses the playback. |
The properties in the category Audio can be used to adjust the audio playback of the movie clip and to select a playback device for the audio channel. Audio playback can be completely disabled with the Audio property and the volume can be adjusted with the Volume property. If the file has multiple audio streams, one can be selected with the Stream property in the Audio category.
Additional to the event driven control, The Movie Clip Node can also be controlled by a Keyframe Animation. To do so simply bind the control Property to any Keyframe Animation Node.
Type | Description |
Play | starts the movie playback at a given time that can be set by the keyframe value |
Pause | pauses the movie clip at the time set in the keyframe value |
Stop | stops the movie playback at the given time. It does not carry a time but looks to its right and left to seek to the needed frame. Sample 1 and Sample 2 at the bottom explain the behavior in detail. |
Sample 2 behaves a little different, in this case the movie starts playing, but when it hits the Stop keyframe it will seek to the position of the Pause keyframe to it's right.
It would show the same behavior at the Stop keyframe if the right one would be a Play instead of a Pause.
Sample 1 | |
Sample 2 | |
When seeking a high-bitrate movie or multiple movies at the same time, it is very likely that the computer is not fast enough to immediately continue playback at the new position. This is especially problematic if multiple machines in a cluster are supposed to playback parts of the same movie clip.
Depending if the machine is part of a cluster, the movie clip node will behave differently:
Not in a cluster (GroupID zero): The movie will pause until enough frames are decoded to guarantee smooth playback.
In a cluster (GroupID not zero): If seeking failed to happen in time, a second seek is made to a time in the future, hoping that it's enough. This is like shooting clay pigeons, don't shoot where it is, but where it will be. If things went right, the first decoded frame will be slightly in the future and displayed until real-time and movie-time are synchronized again.
Ok | Everything is fine |
BadFile | Unsupported file format |
UnknownFormat | Unsupported video codec |
UnsupportedFeature | E.g. unsupported colorspace |
BadFormat | File is somehow corrupted or requires unknown features |
NoVideo | No video stream found |
InternalError | Unknown internal error |
OutOfMemory | Not enough memory for all video frame buffers available |
FfmpegError | Unexpected ffmpeg error |
NoAudio | Audio enabled but no audio stream found |
FileNotFound | Specified file was not found |
The Movie Stream does not need as many Input Properties as the Movie Clip, since looping, seeking or restarting the stream is not possible. The properly properties and fired events are left out in the Movie Stream node. All other Properties as well as the Configuration are similar to the ones of the Movie Clip.
