![]() | Cylinder | This node provides a cylinder (and tube) geometry. |
Renders a cylinder with adjustable dimensions and, optionally, a hole if the Hole property is set to a non-zero value. By decreasing the Angle property, partial cylinders or pie wedges can be created.
