Web Browser | An interactive Internet browser that can be used to render HTML or browse the web. |
The Web Browser node renders web pages into a texture so their content can be used inside a Ventuz scene. Since Ventuz 5.3 this is done based on the Chromium Embedded Framework CEF.
Chromium Embedded Framework CEF can handle maximum 16 inputs per browser.
Code | Description |
13 | Return |
9 | Tab |
8 | Backspace |
127 | Delete |
27 | Escape |
%HOMEDRIVE%\ProgramData\Ventuz5\WebCache
41 | Custom |
The Web Browser node supports the JavaScript scripting language both as part of the content as well as a means of interaction between Ventuz and the site content. This is done by defining input/output properties, methods and events in the Custom Model editor at the bottom of the Property Editor.
<html> <head> <title>Method Test</title> </head> <body> <script type="text/javascript"> function CalculateSquare(value) { var result = value * value; document.write("The square of " + value + " is " + result + "<br>"); ventuz.Result(result); } </script> </body> </html>
Ventuz properties can also be connected to the script code via the Custom Model. They become available as members of the global ventuz object. Changes in the input properties are automatically reflected in the script code but updating outputs have to be explicitly triggered inside the script code by calling the function ventuz.updateOutputs().
<html> <head> <title>Method Test</title> </head> <body> <script type="text/javascript"> function CalculateSquare() { ventuz.result = ventuz.value * ventuz.value; document.write("The square of " + ventuz.value + " is " + ventuz.result+ "<br>"); ventuz.updateOutputs(); } </script> </body> </html>
Example 1:
Example 2:
UP = function() { window.scrollBy(0,-5); } DW = function() { window.scrollBy(0,5); }
Disable Plugin | Plugins (like Adobe Flash) are disabled. |
Allow ClearType | Disables/enables Clear Type. Monochrome scaled text with Clear Type enabled result in colorful edges. |
Allow ventuz:// from external sites | Allows you to reference assets inside a Ventuz Project |
Ignore SSL certification errors | Execution of Java Script code is disabled. |
Audio | Allows you to configure the In and Out Ventuz Ordinals and global browser Volume. Also check the crosspoint section in the Audio Video Config for further information. |
User Agent | Some web sites (like Facebook.com) expect special keys in the user-agent string. The user agent string can be manually adjusted here. See http://www.user-agents.org |
Content Block List | Downloads a filter lists that automatically remove unwanted content from the internet, including annoying adverts and bothersome banners |
