Ventuz contains a feature-rich, non-linear animation system with several ways to create, change and control animations. It is based on the same classic Keyframe Techniques used in other animation packages. The realtime capabilities of Ventuz, however, offer a lot more possibilities than traditional animation tools. Almost every parameter can be animated. Ventuz supports a virtually unlimited number of independent animations, each with its own timeline and keyframes. While breaking the strict relation between scene and timeline, which is very common in most 3D applications. That can be confusing to new users, since it harnesses the power of interactive animation unlike any other software.
Ventuz offers two different types of animations: Procedural Animations are automatically generated animations based on mathematical functions. They can be used for simple movements or to loop background animations; Regular Keyframe Animations on the other hand offer complete control over values and timing of an animation.
The main difference between Ventuz and traditional 3D animation packages is that the order and timing of animations do not have to be predefined. For example, filmmakers design storyboards and develop precise scripts to derive the perfect sequence of events, on the contrary, there is no single perfect sequence in realtime, since one can't anticipate batched events. Perhaps a speaker decides to take another route at the last minute or a football player has an injury in the middle of the game. Ventuz gives the operator the power to play with such elements and react to what is happening.
The simplest way to animate something inside Ventuz is to use the Mover node, one of the most flexible and frequently used nodes. Based on the specified mathematical function, it generates output values that can directly be bound to the Input Property that are to be animated (e.g. the rotation value of an Axis Node). The Mover - via the various Mode options - can be used both for elements of the scene that are continuously animated or for elements that only perform their animation if a certain event occurs. It is safe to say that for the majority of situations, the user will not even have to use the Animation Editor thanks to this single Node.
For more complex animations, the traditional keyframe animation process can be used by binding an Input Property to a Keyframe Animation node to create a new animation. Dragging a property to the Animation Editor adds this property to the existing animation. Alternately, pressing CTRL and clicking on the property (name) achieves the same effect.
Since the creation of a keyframe animation is beyond the scope of this document, please read the documentation of the Animation Editor for further information. In summary, a keyframe animation contains information about the target values of the property at specific points in time called keyframes and the animation will interpolate between those values. This way very complex animations like camera fly-through can be achieved.
What gives states meaning and establishes the connection to the scene are the transitions between them. Sticking with the example above, from the "sub-menu open" state, there might be a transition to the "sub-menu closed" state which has a transition to the "main menu closed" state. There might or might not be a transition that goes directly from "sub-menu open" to "main menu closed", depending on how the author designed the scene. Each transition is associated with a Slice, an animation timeline that is independent of any other animations. When the State Engine changes from one state to another, it triggers the animation of the respective transition. The author is responsible creating a keyframe animation that will change property values in order that the situation associated with the target state is established at the end of the animation, e.g. at the end of the "sub-menu open" to "sub-menu closed" animation; the properties should have changed with the result that the menu appears closed to the audience.
Ventuz provides two kinds of states: Hard States and Soft States. Both represent a point in time on one or more slices; whereas a Hard State has a respective set of keyframes for the animated properties, a Soft State does not. In the vast majority of cases, a Hard State should be used, since the author can specify a set of values that are current at a certain state (i.e. Axis A has the X-position property at 5.1, Y-position property at 2.0, the Material has Alpha at 0%, ...) and store it in the keyframes of the Hard State. Designing an animation slice thus boils down to deciding how the transition between the start and end keyframes should look but the two end points are already set. This also ensures consistency when multiple transitions from and to a state exist.
In contrast, a Soft State is not bound to specific keyframes. Instead, it is the users responsibility so ensure that the values interpolated at the state on each of its slides results in a consistent visual presentation. One example on where to use Soft States is an object that should rotate 360 degrees on a transition from one state to itself again. When using a Hard State, the start and end point would be fixed to a single keyframe and thus only one property value could be used for start and end, making it impossible to assign 0 for the start and 360 for the end. With a Soft State however, the state is independent of any keyframes, so one can be added at the beginning with 0 and one at the end of the animation with 360.
Methods can be applied via drag&drop either to a state or a transition. Another way is to assign one via the context menu open by either on the state or the beginning or end of a transition.
Methods that are used on a state are visualized by the method icon inside the state. Methods on states are so-called Jump Methods which means whenever the method is triggered by an event, the State Engine jumps to that state without playing transitions. On the other hand, methods that are applied to the beginning or end of a transition, define what transition to choose in certain situation. In the example above, triggering the red method Method02 will cause the State Engine to animate the transition S1 - S2.
Condition | |
Always | The applied method is always excecuted even if the State Engine is on another state or transition. This results in a jump to a certain state |
Never | The applied method is never excecuted |
Targeted | The applied method is only executed if the State Engine is on a transition to that state and not at a state. |
Idle | The applied method is executed if the State Engine is idle on that state |
Targeted or Idle | The applied method is executed if the State Engine is idle on that state or on a transition to that state. |
Allow to turn around | Allows to turn on the transition and animate the way back without jumping to the target state and animating back from there. |
Templates are so powerful that Ventuz created a dedicated control application just for templated-based workflows called the Ventuz Director. In Ventuz 3 and before, users had to write their own control application where now they can build custom logics/controls based on the Director Plug-In API.
