Value Switch | This node passes one of a number of input values to the output. All input values have to be of same type. | |
Multi Switch | This node processes multiple inputs and passes the result to the output. One can handle multiple input groups with a single index. |
Single, Integer, Boolean, String, Event, Texture.
All types | Last Changed | The output value is always the last changed value of the input group. |
Integer/Float | Sum | The sum of all input Values. |
Min/Max | The minimum/maximum input value. | |
Average |
The average value of all input values. | |
Boolean | AllOn/AllOff | Output is true if all input booleans are true/false. |
AnyOn/AnyOff | Output is true if at least one input boolean is true/false. | |
SingleOn/SingleOff | Output is true if exactly one input boolean is true/false. | |
String | Concat | The concatenation of all input strings. |
Longest/Shortest | The shortest/longest string. | |
FirstNonEmpty | The first string by index that is not empty. With FirstNonEmptyTrimmed all leading and trailing whitespace characters of that string are removed. | |
Texture | First Valid | The first valid texture by input index. |
