A new container is created in the same way as all other nodes, by dragging the Hierarchy or Content Container to the respective part of the scene. Since this is a very generic node and a scene often contains different containers, it is advisable to give it an appropriate name right away by double clicking on the name of the node. It can even be assigned a new icon by selecting the node and then choosing Node/Icon/Open in the main menu bar. Nodes can be added to a Container by cutting them from the hierarchy, navigating into the Container and then pasting them or just create them inside the Container directly.
An alternative way is to select a node and then use Node/Merge To Container from the main menu bar. This will replace the selected subtree with a container and place the removed nodes inside the container.
Next to merging a selection to a Hierarchy Container it is also possible to merge content nodes to Content Container.
There are basically four different ways of merging:
All container nodes can be easily recognized by their gray triangle on the left inside of the node icon. By double clicking on that triangle or pressing ENTER, the editor leaves the current hierarchy level and switches to the inside of the container. When inside a container, the starting point of the hierarchy is not the familiar scene root T-junction, but the container root, a white triangle. Double clicking on that icon or pressing BACK takes the Hierarchy Editor out of the current container. You can also use the Container Level Up Button or press CTRL + U and Level Down Button or CTRL + D to navigate through the container levels. Pressing inside the Hierarchy Editor will display a popup window with the Hierarchy Container structure of the complete scene. This overview can also be used for navigation; just click on the desired container. A very comfortable way to enter and leave containers is to use the click
By default, a Hierarchy Container is created with one Output Node already inside of it. An Output represents a connection back up to the parent hierarchy level and allows nodes or subtrees to be placed behind the Container.
To expose a property, click on the name of the property in the Property Editor and choose Expose/Edit... from the appearing context menu. The name and category of the property, as it appears on the Layer or Container, can either be kept the same as on the original node or be reassigned in the dialog that opens. Press OK and the square to the left of the property name will change to green, symbolizing that this is now an exposed property. Note that exposed property names have to be unique within a container. Exposing two properties with the same name will not only confuse other Ventuz operators but can also disrupt the binding logic.
To quickly expose a property without changing its name or category, click the small square to the left of the property. To quickly hide a property, click on the square. A double-click will bring up the Expose dialog.
Layers are a special kind of Containers. They can only be placed on the Layer Level - the highest Level of the Scene which can be accessed in the Layer Editor - and thus have no hierarchical relation like Hierarchy Containers. Inside each Container there you can place Content and Hierarchy Nodes and expose their properties like you can do with Hierarchy and Content Containers. To get inside a Layer you have to click the Pencil-Icon on the corresponding Layer. By just clicking the Layer itself you select it like any other Container and make it visible inside the Content Editor to be able to bind its Exposed Properties to other Content Nodes' or Layers' Outputs.
3D Layers work similar to a Hierarchy Container - they have an inner Hierarchy tree that gives instructions to the Renderer. Since Layers do not lie in a Hierarchy themselves they cannot use Output Nodes. All other Layers (except for Layer Groups, Switches and the Photoshop Import) work similar to a Content Container. They have no inner hierarchy but a network of Content Nodes.
Each Layer has a Root Node which is placed inside the Layer and cannot be removed. A 3D Layer's Root Node is found at the very top-left of the Hierarchy Editor. A 2D Layer's Root Node is always visible in the Content Editor and has no horizontal brackets (like Content Nodes) but only their corners around its icon. A Root Node's properties can be bound and exposed like of any other Node as well. Some of its properties are exposed by default, some other need to be exposed manually to make them accessible from outside.
Also Layers cannot be placed inside a Container (since they have to be located on the Layer Level) and therefore you cannot merge them to a Container. For this purpose, there are Layer Groups.
Sometimes an author wants to distribute some customized functionality to another user. The end-user should be able to render and tweak the functionality but not be able to see how it is done. In such a case, the functionality can be wrapped into a container which is then sealed (via Node/Seal Container). There are two types of seals:
When removing a node that exposes a property, the interface property stays intact but is visualized in a light gray color. To remove an interface property definition, either double click on the interface property and press Exclude or use the CleanUp button at the bottom of the Property Editor to remove all interface properties without an corresponding exposing node.
To expose a property to an existing Interface Property, click and select the desired interface property under the Expose... menu or click on the small square to the left of the property to pop-up a choice of existing interface properties. Please note that only interface properties of the correct type will be listed!
When using drag & drop with an Interface Container, all containers in the scene with an interface defined are highlighted with a dark gray border. When dragging the selected container over such an interface container, the target's border changes to red. Releasing in this state will not remove the original node but replace the targets content with that of the source node. The same behavior is achieved by using Edit/Copy and Edit/Paste Container Content from the main menu.
Layers may be turned to Interface Containers in a similar way as Hierarchy and Content Containers. Though, they are only capable of keeping an unexposed property so that bindings will not be lost. Their content cannot be replaced by that of other Interface Layers.
Interface Containers can be used to easily change and update other instances by using the Repository. To do so you can create a Repository Item by dragging an Interface Container into an opened Repository. Now every new instance of this item will reference it and thus can be updated very easily. See Repositories for more information on how to exactly do that.
