![]() | Rectangle | A flat, rectangle shaped mesh primitive. By far the most frequently used geometry in a typical Ventuz scene. |
![]() | Rounded Rectangle | Similar to Rectangle but each corner individually can be made either rounded or sharp. |
![]() | Gradient Rectangle | Similar to Rectangle but can be assigned two color values to create a resolution independent gradient. |
