3D Touch Simulator | Simulates a 3D Touch device to interact with Interaction Nodes. |
By default the Id is set to 10. This is to prevent conflicts with VR-Controllers, since these real controllers already have Id's assigned.
Touch Method | Behavior |
None | The interaction of the controller is disabled |
Volume | The controller itself has to intersect with the volume of the touchable object |
Infinite Ray | An infinitely long, straight ray |
Limited Ray | A straight ray that can be limited in world space with the TouchRange property |
Parabolic Ray | A ray that can be limited in world space with the TouchRange property and that is affected by Gravity - changeable with TouchGravity |
