Mirror Filter | This node can restrict which objects are rendered to a Mirror. | |
Clip Plane Filter | This node can restrict which objects are clipped by a Clip Plane | |
Cubemap Filter | The Cubemap Filter can restrict which objects are rendered to a Cubemap. | |
Rank Filter | The Rank Filter is used in Chroma Keying mode to render parts of the Hierarchy to the Background, Foreground or Garbage Matte. | |
Shadow Filter | Filters Objects for the Shadow Map Rendering. | |
3D Layer Reference Filter | Filters objects for each rendering of a 3D Layer issued by 3D Layer References. |
Condition | Description |
Always | Rendered and visible in the Mirror |
BehindMirror | Not rendered but visible in the Mirror |
BeforeMirror | Rendered but not visible in the Mirror |
Always | Rendered and visible inside the reflection |
InReflection | Not rendered but visible inside the reflection |
Outside | Rendered but not visible inside the reflection |
