VMS runs as a multi-client TCP server on port 20405 (Ventuz 5 VMS listens on port 19405. A list of ports used by Ventuz can be found here: VentuzIpPorts). The actual communication protocol is text based (UTF-8) and accepts simple human readable commands. A user can use a telnet client like Putty or Microsoft Telnet Client to connect to VMS.
Disable VMS
Configure IP Restrictions
SYSTEM | USER | |||
<none> | <none> | -app | -notify | |
No VMS is running | Service | Application | Application | Notification |
VMS Service is running | exit 2 | Notification | Notification | Notification |
VMS Application is running | exit 2 | exit 1 | exit 1 | exit 1 |
VMS Notification is running | Service | exit 1 | exit 1 | exit 1 |
Error | xxxx0000 | No connection to Ventuz Runtime or Designer | |
Warning | 0000xxxx | Connection Ventuz Runtime or Designer, but no renderer/project loaded | |
Ok | 00000000 | Ventuz is up and running. | |
VMS Service is not running. No connection from VMS notification to VMS service. |
route print
This Microsoft page explains in-depth the metric system and how to change the metric at the end of the article.
HELO 250 Completed [104] VZ_108290380002111_BFEBFBFF000106A5_00426-065-0527052-86603 Hello [192.168.3.140:50613]
STATE 211 Status [37] Error [00040000]: ErrorDisconnected
INFO 200 Ok [636] <VentuzInfo> <Version /> <MachineName>LOCAL(VBOX-DOC2013)</MachineName> <Mode>Designer</Mode> <EditionName>Ventuz 4 V4.00.00 x64</EditionName> <GroupID>0</GroupID> <MachineID>0</MachineID> <RateNum>60000</RateNum> <RateDen>1000</RateDen> <PipeModes> <PipeMode>OffScreen</PipeMode> </PipeModes> <ProcessID>1292</ProcessID> <ProcessGUID>a6cd8d0d-c2d3-4d88-b1ef-54cb3593df75</ProcessGUID> <SystemID>VZ_108290380002111_BFEBFBFF000106A5_00426-065-0527052-86603</SystemID> <ProjectGUID>15e6698c-7726-4be1-9ede-3ee1c58d9005</ProjectGUID> <ProjectName>Hockey</ProjectName> </VentuzInfo>
ID 200 Ok [20] VBOX-DOC2013, 0, 0
ID NEW-NAME 1 2 200 Ok [17] ID has been set ID 200 Ok [16] NEW-NAME, 1, 2
GETCFG 200 Ok [130] <VMS> <ProjectPath>C:\Users\Public\Documents\Ventuz4\Projects</ProjectPath> <ProjectPath>G:\PROJECTS</ProjectPath> </VMS>
CLOCK 250 Completed [7] 23470
INST 200 Ok [390] <Installations> <Installation Version="4.00.00" Build="181"> <InstallationDir>C:\Program Files\Ventuz Technology Group\Ventuz 4\</InstallationDir> <DesignerPath>C:\Program Files\Ventuz Technology Group\Ventuz 4\Ventuz.exe</DesignerPath> <RuntimePath>C:\Program Files\Ventuz Technology Group\Ventuz 4\VentuzPresenter.exe</RuntimePath> </Installation> </Installations>
SCAN 200 Ok [18] Scan started ...
SCANSTATE 250 Completed [16] Scan completed
PROJ 200 Ok [44129] <Projects> <Project VPR="false" ID="96077cdf-573b-4f5e-8869-5dcb6e1c4768" FullPath="C:\Users\Public\Documents\Ventuz4\Projects\__HELP__\VentuzHelp\Help1.vzp"> <VentuzVersion>4.0.0.0</VentuzVersion> <Name>Help1</Name> <Author>Ventuz</Author> <Copyright>2019 Ventuz Technology</Copyright> <Category>Ventuz</Category> <ThumbnailBase64>iVBORw0KGgoAAAA..........ggg==</ThumbnailBase64> </Project> ... </Projects>
scenes 15e6698c-7726-4be1-9ede-3ee1c58d9005 200 Ok [216] Templates/FS_LineUp, Templates/FS_Promo, Templates/FS_Scoreboard, Templates/InGame
SM 15e6698c-7726-4be1-9ede-3ee1c58d9005 Templates/FS_Promo 200 Ok [44778] <SceneModel DisplayName="templates/fs_promo" ThumbnailArea="0,0,1,1" Thumbnail="iVBORw0KGgoA........JRU5ErkJggg==" xmlns="http://www.ventuz.com/Ventuz/SceneModel/1.0"> <SceneModel.DataModel> <DataModel> <Animation AnimationName="FS_Promo" Name="FS_Promo" Label="Control" /> </DataModel> </SceneModel.DataModel> <SceneModel.DataModelScene> <DataModel> <Animation AnimationName="FS_Promo" Name="FS_Promo" Label="Control" /> </DataModel> </SceneModel.DataModelScene> <SceneModel.Animations> <AnimationModel Name="FS_Promo"> <AnimationModel.DataModel> <DataModel> <String Default="7:30" MinLines="1" MaxLines="1" RegEx="" Name="Time" Label="Time" Description="Event start time." Mode="RW" /> <String Default="VHL NIGHT" MinLines="1" MaxLines="1" Name="Title" Label="Event" Description="Event title" Mode="RW" /> <String Default="LIVE" MinLines="1" MaxLines="1" Name="FirstLine" Label="FirstLine" Description="FirstLine" Mode="RW" /> <String Default="Event Location" MinLines="1" MaxLines="1" Name="SecondLine" Label="SecondLine" Description="SecondLine" Mode="RW" /> <String Default="City" MinLines="1" MaxLines="1" Name="ThirdLine" Label="ThirdLine" Description="ThirdLine" Mode="RW" /> <String Default="NIGHT" MinLines="1" MaxLines="1" Name="LogoSubtitle" Label="3D league subtitle" Description="3D subtitle below the league logo" Mode="RW" /> <Visual Images="True" Textures="True" Movies="True" Scenes="True" Required="True" Name="Visual01" Label="Left_TeamVisual" Description="The left team visual commonly used for the home team logo." Mode="RW" /> <Visual Images="True" Textures="True" Movies="True" Scenes="True" Required="True" Name="Visual02" Label="Right_TeamVisual" Description="The rightt team visual commonly used for the guest team logo." Mode="RW" /> <Visual Images="True" Textures="True" Movies="True" Name="Visual" Label="BGD_Still" Description="Background image" Mode="RW" /> </DataModel> </AnimationModel.DataModel> ... </SceneModel>
START 15e6698c-7726-4be1-9ede-3ee1c58d9005 200 Ok [23] Process started [680]
The HW command gives detailed information about available hardware, available licenses and installed cultures on the VMS system. The returned XML document is used by the Ventuz Configuration tools to remotely configure the system. The hardware information also contains details about the screen screen configuration of the graphics adapter. (Eyefinity or Mosaic configuration)
HW 200 Ok [60438] <MachineHardware> <License> <Outputs>2</Outputs> <OutputsSDI>2</OutputsSDI> <OutputsIVGA>2</OutputsIVGA> <Cluster>true</Cluster> <Misc /> <OffscreenOnly>true</OffscreenOnly> </License> <Gamepads /> <SerialCOMs /> <MidiInputs> <Device Name="LoopBe Internal MIDI" /> </MidiInputs> <MidiOutputs> <Device Name="Microsoft GS Wavetable Synth" /> <Device Name="LoopBe Internal MIDI" /> </MidiOutputs> <BoardsBinarySource>Enum</BoardsBinarySource> <BoardsBinary>PDw8 ... ... <Adapters> <Adapter Ordinal="0" Vendor="NVidia" GpuCount="1" Width="1920" Height="1080"> <Output X="0" Y="0" W="1920" H="1080" /> </Adapter> <Adapter Ordinal="1" Vendor="NVidia" GpuCount="1" Width="1920" Height="1080"> <Output X="0" Y="0" W="1920" H="1080" /> </Adapter> </Adapters> </MachineHardware>
OPT 200 Ok [3892] <?xml version="1.0" encoding="utf-16"?> <DataModel xmlns="http://www.ventuz.com/Ventuz/SceneModel/1.0"> <Trigger Name="Save" Label="Save" Description="Save the current live options" Mode="W" /> <Trigger Name="Log" Label="Log Stream Statistics" Description="Outputs useful audio and video statistics to the Ventuz log." Mode="W" /> <Group Name="VZ" Label="Ventuz Options"> <Integer Default="0" Min="0" Max="2147483647" Format="0" Name="ID" Label="ID" Mode="RW" /> <Enum Elements="<None>, 3Screens, 4800, 8ktesting, 9x16, Dual, DualScreen, "Full HD", HD, UHD, UHD1, Wall" Format="0" Name="RenderSetup" Label="Render Setup" Mode="RW" /> </Group> <Group Name="REN" Label="Rendering Options"> <Boolean Default="False" Format="Yes;No" Name="Wireframe" Label="Wireframe" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="Stats" Label="Show Statistics" Mode="RW" /> <Group Name="STATS" Label="Statistic Options"> <Boolean Default="False" Format="Yes;No" Name="StatsPerf" Label="Performance Statistics" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="StatsSysInfo" Label="System Statistics" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="StatsGPUInfo" Label="GPU Statistics" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="StatsAVInOut" Label="AV Input/Output Statistics" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="StatsMovie" Label="Movies Statistics" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="StatsHistory" Label="Bar History" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="StatsAccuBars" Label="Accumulated Bars" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="StatsStallGPU" Label="Force GPU Stall" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="StatsUser" Label="User messages" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="StatsWatches" Label="Watches" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="StatsScaleToPreview" Label="Scale to Preview" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="StatsLayerProcessing" Label="Layer Processing" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="StatsTracking" Label="Tracking" Mode="RW" /> <Integer Default="0" Min="1" Max="10" Format="0" Name="StatsFrameCount" Label="Frame Count" Mode="RW" /> </Group> <Boolean Default="False" Format="Yes;No" Name="InputDiag" Label="Show Input Diagnostics" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="BoundingBoxes" Label="Show Bounding Boxes" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="Alpha" Label="Show Key" Mode="RW" /> </Group> <Group Name="AVC" Label="AV Options"> <Group Name="Global" Label="Global Options"> <Integer Default="0" Min="0" Max="10000000" Format="0" Name="SoftwareWatchdogTimeout" Label="Software Watchdog Timeout" Mode="RW" /> </Group> <Group Name="Streams" Label="Stream Options"> <Group Name="DX_0" Label="DirectX DirectX Out automatic"> <Enum Elements="None, Low, Medium, Best" Format="0" Name="Multisampling" Label="Multisampling" Mode="RW" /> <Color Default="0, 0, 0, 127" Alpha="True" Format="c" Name="BorderColor" Label="Border Color" Mode="RW" /> <Integer Default="0" Min="0" Max="256" Format="0" Name="EffectBleed" Label="Effect Bleed" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="VirtualFullscreen" Label="Virtual Fullscreen" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="ShowPointer" Label="Show Mouse Pointer" Mode="RW" /> <Boolean Default="False" Format="Yes;No" Name="PreventQueuing" Label="Prevent D3D Queuing" Mode="RW" /> </Group> </Group> </Group> </DataModel>
OPT .REN.Wireframe 200 Ok [7] False
OPT .REN.Wireframe True 200 Ok [6] True
