The Encoded Stream Out outputs provide a simple pipe based streaming protocol to other processes running on the same machine. This way 3rd party applications can process or distribute the video coming out of Ventuz in real time.
This How To will teach you how to configure and use the Stream Out output in different scenarios.
To use Stream Out we need to create a Device Configuration for it. Head to the configuration tab inside the launcher or configuration editor and create a new device configuration.
After naming and creating your configuration add a Stream Out to the right output side via drag and drop.
The properties of this output type only differ in 4 ways vs other output types.
Encode Mode:
Rate Control Mode:
Bitrate:
Constant QP:
If you need detailed information about the other properties available on this output, take a look here
Previously when using this mode, the stream is not sent anywhere by default. These settings are usually needed to enable your own custom program with your own tools to catch or use this stream via our Ventuz Stream Out API.
In Version 8, we provide one implemented and a 3rd party way to do this:
The Stream Out outputs now have a "SRT Output URI" option. This takes any srt:// URL and streams a MPEG-TS stream with the encoded video and high bitrate MP2 audio.
For a simple test setup try the following:
Issues can arise with the localhost part of the URL when IPV6 is still active in a network adapter, when no stream can be detected try using 127.0.0.1 plus port or disable IPV6.
GStreamer https://gstreamer.freedesktop.org/ is a open source framework / library / tool collection for ingesting, processing and outputting video and audio. What our plugin does is interface our Encoded Stream Out outputs with GStreamer so users can grab the encoded video and PCM audio and process it further - for example transcode it and send it to a streaming server.
The plugin and documentation can be found here: https://github.com/VentuzTechnology/Ventuz-GStreamer-Plugin
