Live Video | This node provides video input from SDI/DVI input cards, webcams, TV tuners, DV device, etc. as a texture. | |
Movie Clip | This node loads movies of many file formats and provides their content as a texture. | |
Movie Frame | This node provides single frames of a movie clip. | |
Movie Stream | This node provides single frames of a movie stream. |
Name | Description | Standard | Supported on |
LTC_ | LTC timecode | RP 188 | Deltacast, DVS, Black Magic |
VIT1 | VITC timecode field 1 | RP 188 | Deltacast, DVS, Black Magic |
VIT2 | VITC timecode field 2 | RP 188 | Deltacast, DVS, Black Magic |
AFD_ | Advanced Format Description | SMPTE 2016 | Deltacast, DVS |
AFD Code | Value 4:3 | Description for 4:3 | Value 16:9 | Description for 16:9 |
-/- | -1 | AFD not found | -1 | AFD not found |
0000 | 0 | undefined | 1 | undefined |
0001 | 2 | reserved | 3 | reserved |
0010 | 4 | not recommended | 5 | not recommended |
0011 | 6 | not recommended | 7 | not recommended |
0100 | 8 | letterbox with bar data | 9 | letterbox with bar data |
0101 | 10 | reserved | 11 | Reserved |
0110 | 12 | reserved | 13 | Reserved |
0111 | 14 | reserved | 15 | Reserved |
1000 | 16 | full-frame 4:3, same as coded | 17 | full frame 16:9, same as coded |
1001 | 18 | full-frame 4:3 | 19 | pillarbox 4:3 |
1010 | 20 | letterbox 16:9 | 21 | full-frame 16:9 |
1011 | 22 | letterbox 14:9 | 23 | pillarbox 14:9 |
1100 | 24 | reserved | 25 | reserved |
1101 | 26 | full-frame 4:3 with alternate 14:9 center | 27 | pillarbox 4:3 with alternate 14:9 center |
1110 | 28 | letterbox 16:9 with alternate 14:9 center | 29 | full-frame 16:9 with alternate 14:9 center |
1111 | 30 | letterbox 16:9 with alternate 4:3 center | 31 | full-frame 16:9 with alternate 4:3 center |
bit 9 | bit 8 | bit 7 | bit 6 | bit 5 | bit 4 | bit 3 | bit 2 | bit 1 | bit 0 |
!Parity | Parity | 0 | code3 | code2 | code1 | code0 | Aspect | 0 | 0 |
bit 31..7 | bit 6 | bit 5 | bit 4 | bit 3 | bit 2 | bit 1 | bit 0 |
0..0 | 0 | 0 | code3 | code2 | code1 | code0 | Aspect |
The Movie Clip node gives the Ventuz operator more control over initialization and playback of movie clips. It provides frame accurate playback for use in Ventuz Cluster setups and is able to play the most common video container formats like WMV, AVI, MOV and MKV. Moreover, it is capable of playing Quicktime movies in Ventuz. For all full list of supported video codecs, see Supported Video Formats. The video decoder in this node is based on the FFMPEG project and provides the best performance compared to pre-installed DirectShow and WMF decoders.
With Color Space the automatically detected color space from the file can be overwritten. Ventuz converts from the read out color space to the Project Color Space. Standard setting is Auto to read out the metadata. With Unspecified Ventuz skips the conversion and uses the color values as they are. The other listed modes like BT.709 are presets for specific primaries, a transfer function and matrix, which also can be set independently.
Disable Threading
Enable Audio Compensation
Ignore Clip Duration
Preserve | The node stays in the active state (Play or Pause). |
Play | The node starts playing once seek has completed. |
Pause | The node seeks to the requested frame, displays it and pauses the playback. |
Type | Description |
Play | starts the movie playback at a given time that can be set by the keyframe value |
Pause | pauses the movie clip at the time set in the keyframe value |
Stop | stops the movie playback at the given time. It does not carry a time but looks to its right and left to seek to the needed frame. Sample 1 and Sample 2 at the bottom explain the behavior in detail. |
Sample 2 behaves a little different, in this case the movie starts playing, but when it hits the Stop keyframe it will seek to the position of the Pause keyframe to it's right.
It would show the same behavior at the Stop keyframe if the right one would be a Play instead of a Pause.
Sample 1 | |
Sample 2 |
Ok | Everything is fine |
BadFile | Unsupported file format |
UnknownFormat | Unsupported video codec |
UnsupportedFeature | E.g. unsupported colorspace |
BadFormat | File is somehow corrupted or requires unknown features |
NoVideo | No video stream found |
InternalError | Unknown internal error |
OutOfMemory | Not enough memory for all video frame buffers available |
FfmpegError | Unexpected ffmpeg error |
NoAudio | Audio enabled but no audio stream found |
FileNotFound | Specified file was not found |
