In order to keep a project on its tracks when working with it over longer time it is advised to write project documentation describing the project in more detail, or including guidelines so your colleagues and future you know what to do.
With Ventuz 8, we have introduced the ability to write your documentation in HTML or Markdown and have it displayed inside of Ventuz. We have implemented Markdig https://github.com/xoofx/markdig. The following section will show you how to do so.
After you've created your project, some documents are automatically created and updated each time you close your project. You will find a Documentation folder in your project file structure where a project report has been created. If thats not case you can create the folder yourself.
Inside this folder you will need to create a index.md file. This can then be edited by your favourite text editor. We recommend notepad++. After you created the file and your Designer is running with that project you will see that a index.html is created automatically. If you Designer is not running it will be created as soon as you open that project. The html is needed so we can actually display it inside the Designer.
While Markdown is widely used, it, sadly, is not standardized; therefore, searching the web for specific syntax might not work for you. Thats why we provide a list of syntax that works here.
List of markdown syntax that works: Try copying this into your index.md file to see how this works for you.
# General !MarkDown Syntax horizontal lines: ____ ---- normal Text *italics* **bold** ***bold italics*** ~~deleted~~ ++Inserted text++ ==Marked text== H~2~O is a liquid. 2^10^ is 1024 Warnings: > [!Warning] > This will produce a warning sign above the text Caution, note and info also produce different emojis # Links auto links: https://www.ventuz.com link (anchor) to [H1 Header] # H1 Header Plain Text ## H2 Header Plain Text ### H3 Header Plain Text # Quotes > quote line 1 > quote line 2 > quote line 3 # Lists 1. ordered list 1. ordered list continued text of item 1 $ indented code block line 1 $ indented code block line 2 continued text of item 1 1. ordered list a. ordered list a. ordered list a. ordered list a. ordered list * unordered list second paragraph * unordered list * unordered list * * unordered list * * # Task lists - [ ] Task 1 - [x] Task 2 - [ ] Task 3 \# is escaped # Heading with style Setext headings Foo *bar* ========= Setext headings Foo ***bar*** --------- # Code Blocks a simple indented code block fenced code block ~~~ fenced code block line 1 fenced code block line 2 ~~~ Inline `code` is written like this. # Pipe tables header a | header b - | - item 0 | item 1 item 2 | item 3 # Grid Tables +---------+---------+ | Header | Header | | Column1 | Column2 | +=========+=========+ | 1. ab | > This is a quote | 2. cde | > For the second column | 3. f | +---------+---------+ | Second row spanning | on two columns +---------+---------+ | Back | | | to | | | one | | | column | | # YouTube ![youtube.com](https://www.youtube.com/watch?v=mswPy5bt3TQ) # Footnotes Here is a footnote[^1]. And another one[^2]. And a third one[^3]. And a fourth[^4]. [^1]: Footnote 1 text [^2]: Footnote 2 text # abbrevations Use abbrevations for complex words like VMS *[VMS]: Ventuz Machine Service # Images embedded data: url ![image](data:image/png;base64,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) remote from https://www.ventuz.com/wp-content/uploads/2019/10/ventuz-logo-weiss-300x86.png?x10618 ![image](https://www.ventuz.com/wp-content/uploads/2019/10/ventuz-logo-weiss-300x86.png?x10618) remote via HTML with size <img src="https://www.ventuz.com/wp-content/uploads/2019/10/ventuz-logo-weiss-300x86.png?x10618" width="200"/> centering a image <p style="text-align:center;"><img src="bgd1.png"></p> local file kjhlkjh ![image](image.jpg) You can also put the [link URL][1] below the current paragraph like [this][2] and reference the same embedded image ![image][img1] multiple times ![image][img1] [1]: http://url [2]: http://another.url "A funky title" [img1]: data:image/png;base64,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 "My Image" # Diagrams (mermaid) Mermaid Diagramming and charting tool https://mermaid.js.org/ ## graph ```mermaid graph TD; A-->B; A-->C; B-->D; C-->D; ``` ## sequenceDiagram ```mermaid sequenceDiagram loop Daily query Alice->>Bob: Hello Bob, how are you? alt is sick Bob->>Alice: Not so good :( else is well Bob->>Alice: Feeling fresh like a daisy end opt Extra response Bob->>Alice: Thanks for asking end end ``` ## Pie Chart ```mermaid pie title What Voldemort doesn't have? "FRIENDS" : 2 "FAMILY" : 3 "NOSE" : 45 ```
