Float Expression | Provides the possibility to write logical C# expressions with a Float as resulting output value. | |
Double Expression | Provides the possibility to write logical C# expressions with a Double as resulting output value. | |
Int Expression | Provides the possibility to write logical C# expressions with an Int as resulting output value. | |
String Expression | Provides the possibility to write logical C# expressions with a String as resulting output value. | |
Boolean Expression | Provides the possibility to write logical C# expressions with a Boolean as resulting output value. Additional it provides True and False Event outputs. | |
Date Time Expression | Provides the possibility to write logical C# expressions with Date Time as resulting output value. | |
Float Array Expression | Provides the possibility to write logical C# expressions with a Float array as resulting output value. | |
Double Array Expression | Provides the possibility to write logical C# expressions with a Double array as resulting output value. | |
Int Array Expression | Provides the possibility to write logical C# expressions with an Int array as resulting output value. | |
String Array Expression | Provides the possibility to write logical C# expressions with a String array as resulting output value. | |
Boolean Array Expression | Provides the possibility to write logical C# expressions with a Boolean array as resulting output value. Additional it provides True and False Event outputs. | |
Byte Array Expression | Provides the possibility to write logical C# expressions with a Byte array as resulting output value. | |
Dynamic Expression | Provides the possibility to write logical C# expressions with the ability to manual define in and output values. |
String expressionMethod(String A, String B, String C, String D) { return EXPRESSION; }
{ STATEMENTS return RESULT; }
A + B | Sum of A and B for numeric expressions or the concatenation for string expressions. |
(A + 1.0) * B | Product of B and the sum of A and 1. |
Math.Sin(A / 180.0 * Math.PI) | Sine of the input degrees given in angle. |
Math.Asin(A) * 180.0 / Math.PI) | Inverse sine of the given value A, converted to degrees. |
(A == 6) ? 1:0 | Return 1 if A is equal to 1.6, otherwise return 0. |
(A != B) ? 1:0 | Return 1 if A is not equal to B, otherwise return 0. |
(A < 0) ? 0 : A | Return 0 if A is smaller than 0, otherwise return A. |
(A >= 0) ? 0 : A | Return 0 if A is greater than or equal to 0, otherwise return A. |
(A < 10) ? 10: ( (A > 20) ? 20 : A) | Returns A clamped into the the interval 10 to 20. |
(double)(int)A | Converts A into an integral value (all fractions are removed) and converts it back to double. |
Convert.ToString( Convert.ToInt32(A) * Convert.ToInt32(B)) | Convert the two input strings to integers, multiply them and convert the result back to a string |
{ int b = 0; for(int i = 1; i <= A; i++) b = b + i; return b; } |
{ int b = 1; if(A<=1) return 1; for(int i = 1; i < A + 1; i++) b = b * i; return b; } |
{ int result = 0; for(int i = 0; i < A.Length; i++) { result += A[i]; } return result; } |
System.DateTime.UtcNow.AddHours(2) |
{ Array.Sort(A); return A; } |
using System; using System.Linq; using System.Xml.Linq;
Since the System namespace has been made available, all functions in the Math Namespace, theConvert Class and all String operations are supported.
