Data Rate | SMPTE | Links | Resolution, Maximal Framerate, Description | ||||
270 Mb/s | 525i60, 625i50 | ||||||
ST 259 | SD | full raster | |||||
1.5 Gb/s | 1080i60, 1080p30, 720p60 | ||||||
ST 292-1 | HD | full raster | |||||
3.0 Gb/s | 1080p60 | ||||||
ST 425-1 | 3GA | LevelA : full raster | |||||
ST 372 | 2xHD | interleaved lines | |||||
ST 425-1 | 3GB | LevelB : 3G link carries a HD Dual Link stream muxed | |||||
6.0 Gb/s | 2160p30 | ||||||
none | 4xHD | image quadrants | |||||
ST 425-3 | 2x3GB | 2x 3G Level B-DS links carry 4 HD streams as two samples interleaved | |||||
ST 2081-10 | 6G | full raster | |||||
12.0 Gb/s | 2160p60 | ||||||
none | 4x3GA | image quadrants | |||||
ST 425-5 | 4x3GA | 4 3G links as two samples interleaved | |||||
ST 2081-11 | 2x6G | interleaved pixels across 2 streams | |||||
ST 2082-10 | 12G | full raster | |||||
24.0 Gb/s | 4320p30 | ||||||
none | 4x6G | image quadrants | |||||
ST 2081-12 | 4x6G | interleaved pixels across 4 streams | |||||
48.0 Gb/s | 4320p60 | ||||||
none | 4x12G | image quadrants | |||||
ST 2082-12 | 4x12G | interleaved pixels across 4 streams |
Format | SD | 1080i60 | 1080p60 | 2160p30 | 2160p60 | 4320p30 | 4320p60 | |||||||||
Links | SD | HD | 2xHD | 3G A | 3G B | 4xHD | 2x3G B | 6G | 4x3G A | 4x3G A | 2x6G | 12G | 4x6G | 4x12G | ||
SMPTE ST | 259 | 292-1 | 372 | 425-1 | 425-1 | none1 | 425-3 | 2081-10 | none1 | 425-52 | 2081-11 | 2082-10 | none1 | 2081-12 | none1 | 2081-22 |
Deltacast | ||||||||||||||||
DELTA-12G1c-hmi10-elp | X | X | - | X | X5 | X | X | no key3 | X | X | - | no key3 | - | - | - | - |
DELTA-12G-ELP-H-4C | X | X | - | X | X5 | X | X | X | X | X | - | X | X | X | X | X |
DELTA-12G-ELP-H-2C | X | X | - | X | X5 | X | X | X | X | X | - | X | - | - | - | - |
DELTA-3G-elp-key-d 4k | X | X | X | X | X5 | X | X | - | X | X | - | - | - | - | - | - |
DELTA-3G-elp-key-d 2k | X | X | x | X | X5 | X | X | - | - | - | - | - | - | - | - | - |
DELTA-3G-elp-d 4c/8c | X | X | X | X | X5 | no key3 | no key3 | - | no key3 | no key3 | - | - | - | - | - | - |
DELTA-3G-elp-2key-d 22/44 | X | X | X | X | X5 | X | X | - | - | - | - | - | - | - | - | - |
DELTA-3G-* | X | X | - | X | X5 | - | X | - | - | - | - | - | - | - | - | - |
DELTA-HD-e-key 22/11 | X | X | - | - | - | - | - | - | - | - | - | - | - | - | - | - |
DELTA-HD-ELP-D-44/80 | X | X | X | - | - | X | - | - | - | - | - | - | - | - | - | - |
DELTA-HD-* | X | X | - | - | - | - | - | - | - | - | - | - | - | - | - | - |
FLEX-12G 10 01 | X | X | - | X | X5 | no key3 | no key3 | no key3 | no key3 | no key3 | - | no key3 | - | - | - | - |
FLEX-3G 40 04 | X | X | X | X | X5 | - | - | - | no key3 | no key3 | - | - | - | - | - | - |
Black Magic Design | ||||||||||||||||
Decklink 8K Pro | X | X | no key3 | X | X | - | no key3 | X | - | - | - | X | - | X | - | X |
Decklink 4K Extreme 12G | X | X | no key3 | X | X | - | no key3 | X | - | - | no key3 | X | - | - | - | - |
Decklink 4K Extreme | X | X | no key3 | X | X | - | no key3 | X | - | - | out only | - | - | - | - | - |
Decklink HD Extreme 3 | X | X | - | X | X | - | - | - | - | - | - | - | - | - | - | - |
Decklink Duo/Quadro 2 | X | X | - | X | X | - | - | - | - | - | - | - | - | - | - | - |
Decklink Mini Monitor 4K | X | X | - | X | X | - | - | X | - | - | - | - | - | - | - | - |
Decklink Mini Recorder 4K | X | X | - | X | X | - | - | X | - | - | - | - | - | - | - | - |
UltraStudio HD Mini | X | X | - | X | X | - | - | - | - | - | - | - | - | - | - | - |
Aja | ||||||||||||||||
Kona 5 4 | X | X | - | X | X | no key3 | no key3 | X | no key3 | no key3 | - | X | X | X | X | X |
Kona 4 | X | X | - | X | X | no key3 | no key3 | - | no key3 | no key3 | - | - | - | - | - | - |
Kona 3 | X | X | - | X | - | - | - | - | - | - | - | - | - | - | - | - |
Kona LHi | X | X | - | X | - | - | - | - | - | - | - | - | - | - | - | - |
Kona LHe+ | X | X | - | - | - | - | - | - | - | - | - | - | - | - | - | - |
Corvid 44 12G 4 | X | X | - | X | X | - | - | X | - | - | - | X | X | X | X | X |
Corvid 88 | X | X | - | X | X | X | X | - | X | X | - | - | - | - | - | - |
Io 4k Plus | X | X | - | X | X | no key3 | no key3 | - | no key3 | no key3 | - | - | - | - | - | - |
Io X3 | X | X | - | X | X | - | - | - | - | - | - | - | - | - | - | - |
Io 4K | X | X | - | X | X | no key3 | no key3 | - | no key3 | no key3 | - | - | - | - | - | - |
Io XT | X | X | - | X | - | - | - | - | - | - | - | - | - | - | - | - |
Datapath | ||||||||||||||||
Vision LC SDI | X | X | - | X | X | - | - | - | - | - | - | - | - | - | - | - |
Vision AV SDI | X | X | - | X | X | - | - | - | - | - | - | - | - | - | - | - |
Boards are also limited by the number of connectors and capabilies from the table below. For instance, a Delta-3G 11 with one input and one output can not do key+fill because that would require two outputs, and it can not do internal hardware keying because in the table below it says that "DELTA-3G-*" boards can not do internal hardware keying.
Feature summary and exlenation of sortcuts:
Series / Model | audio | autodetect | k+f | keyer | duplex | multiformat | bypass | Timecode | AFD | Tracking | ECK | HDR | Specials |
DELTA-12G-* | yes | yes | yes | - | yes | timebase | - | yes | yes | yes | yes | yes | softkey |
DELTA-3G-elp-key-d 4k | yes | yes | yes | yes | yes | timebase | (yes)6 | yes | yes | yes | yes | yes | softkey, key-input, key-delay |
DELTA-3G-elp-key-d 2k | yes | yes | yes | yes | yes | timebase | (yes)6 | yes | yes | yes | - | ? | softkey, key-input, key-delay |
DELTA-3G-elp-d 4c/8c | yes | yes | yes | - | yes | timebase | - | yes | yes | yes | yes | yes | softkey |
DELTA-3G-elp-2key-d 22/445 | yes | yes | yes | yes | yes | timebase | yes | yes | yes | yes | - | yes | softkey, key-input, key-delay |
DELTA-3G-* | yes | yes | yes | - | yes | timebase | - | yes | yes | yes | yes | ? | softkey |
DELTA-hd-e-key 22 | yes | yes | yes | yes | yes | timebase | yes | yes | yes | yes | - | - | softkey, key-input, key-delay |
DELTA-hd-e-key 11 | yes | yes | - | yes | yes | timebase | yes | yes | yes | yes | - | - | softkey, key-input |
DELTA-HD-* | yes | yes | yes | - | yes | timebase | - | yes | yes | yes | yes | - | softkey |
FLEX-12G 10 01 | yes | yes | - | - | - | timebase | - | yes | - | - | - | yes | |
FLEX-3G 40 04 | yes | yes | - | - | - | timebase | - | yes | - | - | - | ? | |
Blackmagicdesign | |||||||||||||
Decklink 8k Pro | yes | yes | yes | yes2 | yes | yes | - | yes | - | yes | yes | yes | RGB444 |
Decklink 4k Extreme 12G | yes | yes | yes | yes2 | yes | - | - | yes | - | yes | - | yes | RGB444 |
Decklink 4k Extreme | yes | yes | yes | yes2 | yes | - | - | yes | - | yes | - | ? | RGB444 |
Decklink Extreme 3D3 | yes | yes | yes | yes2 | - | - | - | yes | - | - | - | ? | |
Decklink Duo/Quad 2 | yes | yes | yes | yes2 | yes | yes | - | yes | - | yes | yes | no | RGB444 |
Decklink Duo/Quad | yes | yes | - | - | - | - | - | yes | - | yes | - | yes | will appear as multiple devices |
Decklink Mini Monitor 4k | yes | yes | - | - | yes | - | - | yes | - | - | - | ? | RGB444 |
Decklink Mini Recorder 4k | yes | yes | - | - | yes | - | - | yes | - | - | - | ? | RGB444 |
UltraStudio HD Mini | yes | yes | yes | yes | yes | - | - | yes | - | - | - | ? | |
VisionLC-SDI | - | - | - | - | - | - | - | - | - | - | - | - | |
VisionSC-SDI4 | - | - | - | - | - | - | - | - | - | - | - | - | |
VisionSC-HD4+ | - | - | - | - | - | - | - | - | - | - | - | - | |
VisionAV-SDI2 | - | - | - | - | - | - | - | - | - | - | - | yes | |
AJA | |||||||||||||
Kona 57 | yes | yes | yes | yes | yes | - | - | - | - | yes | yes | yes | |
Kona 4 | yes | yes | yes | yes | yes | - | - | - | - | yes | yes | yes | |
Kona 3G | yes | yes | yes | yes | yes | - | - | - | - | yes | - | ? | |
Kona LHi | yes | yes | - | yes | yes | - | - | - | - | yes | - | ? | |
Kona LHe+ | yes | yes | yes | yes | yes | - | - | - | - | yes | - | ? | |
Corvid 44 12G (BNC or not) | yes | yes | yes | yes | yes | - | - | - | - | yes | yes | yes | |
Corvid 88 | yes | yes | yes | yes | yes | - | - | - | - | yes | yes | yes | |
Io 4K Plus8 | yes | yes | yes | yes | yes | - | - | - | - | yes | yes | yes | |
Io X38 | yes | yes | yes | yes | yes | - | - | - | - | yes | yes | yes | |
Io 4K8 4 | yes | yes | yes | yes | yes | - | - | - | - | yes | yes | ? | |
Io XT8 | yes | yes | yes | yes | yes | - | - | - | - | yes | - | ? |
Limitations:
Some lines in the table describe a whole category of products. If a certain option requires more jacks than the board offers, the mode is obviously not supported. For instance, a Blackmagic Decklink board with only one output can not support key+fill, while it's larger brother with two outputs will.
Ventuz supports the following ST 2110 boards
Vendor | Model | Speed | SPS 1 | Channels | Notes |
Deltacast | DELTA-ip-ST2110 10 | 10 GBit/s | yes | 4 In | |
Deltacast | DELTA-ip-ST2110 01 | 10 GBit/s | yes | 4 Out | |
Aja | Kona IP | only output | 4 In / Out | end of production |
Deltacast | HD / 3G / 12G Series KEY Series DVI / H4k Series FLEX Series |
Recommended boards
Supported FLEX modules
Current Versions
Ventuz | Mainstream Driver | Legacy Driver | Experimental Driver | Note |
8.00.00 | 6.22.1 rc 1 | 6.13.1 | patched driver, "v6.22_rc1.zip" | |
7.00.00 | 6.15.1 | 6.13.1 | 6.20.0 | introduced experimetal drivers |
6.08.00 | 6.15.1 | 6.13.1 | introduced legacy drivers | |
6.06.00 | 6.13.1 | |||
6.04.01 | 6.8.1 patch 3 | patched driver, "v6.08.01_h4k2_EDID_Build3" | ||
6.02.00 | 6.8.1 patch 2 | patched driver, "v6.08.01_h4k2_EDID_Build_2" |
You can download the driver from the Ventuz support website at http://www.ventuz.com/drivers.
Some versions use a patched version of the driver which is not available from the Deltacast website. Please always use the drivers in the driver folder of the Ventuz installation directory and not the drivers from the deltacast website.
Legacy Drivers
As of Ventuz 6.8, Ventuz will detect the installed drivers for deltacast boards and then choose the correct Deltacast SDK libraries.
If you have one of the old boards that are not supported by the latest deltacast SDK, install 6.13.1 drivers for all boards. Otherwise install the drivers that come with the ventuz installation for all boards, as that will have significantly better performance. Ventuz will then load the correct SDK libraries.
If you have multiple deltacast boards and mix drivers, Ventuz will load the "mainstream" libraries and the boards using 6.13.1 are not usable. Boards with any other driver will also be not usable.
So be aware mixing boards that require old drivers (like the DELTA-HD-e-key 22) and new boards that only work with mainstream drivers (like DELTA-12G1c-hmi10-elp).
Internal Keying
The only 3G board that can do 4k 60Hz SMPTE ST 425-5 (aka 2si) external keying is the DELTA-3G-elp-key 4K.
12G key+fill can be confusing to configure, as the 12G-elp-h 4c and 12G-elp-h 2c boards output 6G/12G key+fill on TX0 / TX4, and the second pair on TX2 / TX6, while 3G will be output on TX0 / TX1 and TX2 / TX3 as you would expect. In the device config you need to first choose "external keying" and then the right combination of output ports to have the desired video format available on your output.
Tracking Source
The tracking source feature allows to align the timing of camera tracking data with an SDI signal. Since Ventuz V8.0, outputs can be used for this in addition to inputs. For this to work, the output must be locked to a genlock input and the genlock frequency must be manually selected, not set to "autodetect.". Inputs always work.
Genlock Offset
It is possible to use a different video format for the genlock signal then for the output that is to be synchronized, as long as the refresh rate is the same. For instance, using PAL as genlock and 720p50 as output is ok. But notice that for deltacast boards, the video format of the output defines the units for the genlock offset: changing the genlock by one line will change the genlock by one line in 720p, not one line in PAL. This also works with genlock format set to auto, since the video format of the output stream is always known. If multiple outputs with different video format are defined, the effect of the genlock offset is unspecified.
Memory Pre-Allocation
[http://ventuz.com/sites/default/files/downloads/files/drivers/deltacast_mem_pre_alloc.zip download] this registry file from www.ventuz.com
AJA | Kona / Corvid |
External devices:
Corvid boards are intended for situations where a developer bundles their software with a Aja hardware. Driver and tool support by Aja is limited and hidden behind a login that is only allowed for registered developers. Expect inconveniences when using a Corvid board!
This means that the board generally works with standard Venutz, but there are complicated limiations, please check with us.
Ventuz 4 | Ventuz 5 | Ventuz 6 | Ventuz 7 | Driver |
8.00.00 | 16.2.5 | |||
6.08.00 | 7.00.00 | 15.5.3.1 | ||
6.06.00 | 15.5.1.2 | |||
4.05.00 | 5.00.00 | 6.00.00 | 12.0.0.123 |
Problems Installing Drivers
The Kona 5 and Corvid 44 12G come with different firmwares, each firmware has a different feature set. As there are different tools to flash a Corvid firmware, the names for equivalent firmwares are different.
Kona5 Firmware | 4k | n/a | 8K | 12 Bit |
Corvid44 12G Firmware | n/a | 8KMK | 8K | 2x4K |
input / output | SD/HD/3G | SD/HD/3G | HD/3G/6G/12G | no |
quad link input / output | HD/3G | HD/3G | 6G/12G | no |
internal keying | SD/HD/3G (2x) | SD/HD/3G (1x) | no | 6G/12G |
external keying | SD/HD/3G (2x) | SD/HD/3g (1x) | no | 6G/12G |
We recommend:
The Aja control panel supports switching the firmware of Kona-5 boards without reboot, this is called the "fast" option. This may be useful when you need to experiment with the different modes.
These "fast" firmwares behave identical to the normal ones, only that the board will revert to the original state on next shutdown / reboot, as the firmware is not actually "flashed".
The Corvid44 12G must be configured with a commandline tool. The Aja Control Panel detects the board but does not provide the required firmwares.
Many older boards have two firmwares : UFC and Quad. Ventuz is tested with the Quad firmware only.
Black Magic Designs | Decklink series Intensity series UltraStudio series |
Legacy models that we tested:
Other models should work as long as they are supported by the 12.x drivers.
Ventuz | Desktop Video Driver | Comment |
8.00.00 | 12.7.1 | |
6.12.00 | 12.4.0 | Major version bump, 12.x driver required |
6.08.00 | 11.4.1 | |
6.06.00 | 11.4.1 | Major version bump, 11.x driver required |
6.00.00 | 10.8.4 | fixes for Windows 10 anniversary update |
5.00.00 | 10.3.1 | Major version bump, 10.x driver required |
4.00.00 | 9.7.7 |
You can download the drivers directly from Black Magic Design at https://www.blackmagicdesign.com/support/family/capture-and-playback
The 8K Pro is currently the most powerful SDI board by BMD with 4 individually configurable 12G SDI jacks.
Please mind the following when trying to configure it:
Very old boards, like the Extreme 3d, can only have input or output, not both at the same time. All models currently on sale support simultanous input and output.
This does not apply to the duo / quad boards and the 8K Pro.
When getting video from HDMI / DVI inputs, you must specify if the input is in RGB 4:4:4: or YUV 4:2:2. This is done with the board options. When using autodetect, this will be done automatically.
Datapath | VisionRGB VisionAV VisionSC |
We explicitly tested the following bords
Other bords from the VisionRGB / VisionAV / VisionSC series should also work.
We only support datapath capture boards, no graphics boards.
Ventuz 4 | Ventuz 5 | Ventuz 6 | Ventuz 7 | Ventuz 8 | Driver SC / AV / RGB | Driver LC |
6.06.00 | 7.00.00 | 8.00.00 | 7.20.35001.1 | 1.2.4.35006 | ||
4.05.00 | 5.00.00 | 6.00.00 | 7.11.0.1028 |
DVS | Centaurus II (LT) Atomix series |
Atomix Series
Ventuz 4 | Ventuz 5 | Ventuz 6 | Ventuz 7 | Ventuz 8 | Driver |
6.08.00 | 7.00.00 | 8.00.00 | deprecated | ||
4.00.00 | 5.00.00 | 6.00.00 | 4.3.5.10 |
NewTek | iVGA/AirSend NDI (Network Device Interface) |
Formats
Ventuz supports NDI, NDI HX and NDI HX2. The Image format is totally Size/Aspect independent. For further and latest informations about NDI please visit the Wikipedia NDI page.
Key+Fill
Possible amount of Inputs
Possible amount of Outputs
This depends on the license you have. Only the Enterprise license supports four outputs. All others can only have one NDI output. The maximum output resolution is limited by the License only. Please see the Edition Comparisons for reference.
Usefull Information
Syncing / Frame Locking
Windows Media Foundation |
AWS CDI |
CDI is not enabled in every Ventuz Edition. Check our website for further information or get in contact with our sales team (sales@ventuz.com)
AMD | Radeon Pro Series (recommended) FirePro Series (recommended) Radeon Series (with limitations) |
Nvidia | Quadro Series (recommended) Geforce Series (with limitations) |
The NVIDIA Quadro Digital Video Pipeline is not supported by Ventuz. The SDI output of these board family can be used as monitor output. External key, Audio and other features of this product line are not address by Ventuz.
Intel | Intel integrated graphics |
Direct3D | Windows compatible graphics board |
Vendor | Input | Output |
Aja | X | X |
Black Magic | X | |
Deltacast | X |
Trackmen Egripment | Trackmen Products |
NCam | NCam |
Stype Kit | Stype Kit |
Mo-Sys StarTracker | StarTracker |
HTC Vive integrated through Open VR |
Oculus Rift integrated through Open VR |
