Auto-routing between states
A Template is an entity that describes both the logical and visual parts of a scene that can be activated in conjunction with its corresponding data. Every scene automatically defines a Scene Template, which represents the scene without any predefined data. All other templates in the scene are defined by the Present States of the animation logic and are usually associated with some dynamic data. All Templates defined by a scene are organized in a hierarchical order that also declares their relationship between each other (Concurrency, Dependency, Independency). Collections of Templates within a single scene are always organized as a Template Host. Template Hosts are organized as a host-tree, where each host has one parent host (except for the root) and has one or more sub-hosts.
Relationships
If the template engine is used Scene-comprehensively, it defines the root of the host-tree. For every scene that is injected into the project template host one Template is defined. This means all scenes managed by this host are concurrent and there can be a maximum of one scene active at a time.
Animation1 Group2_Animation2 Group2_Animation3
Name | C# Type | Modes | Description | Attributes |
Animation | - | - | The Animation item defines a field that addresses a possible sub-template. The actual value of this field is null or a data instance (TemplateData) of a sub-template. | Required |
Trigger | - | RW | A Trigger can be either an asynchronous event sent out to the remote client (R), a trigger sent from the remote client to Ventuz (W) or both (RW). | |
Group | - | (RW) | A Group contains multiple sub-DataItems and acts like a folder. The mode is the sum of all sub-items only defines if the items below are readable and/or writable. The group itself has no value. | |
Float | float | RW | A floating point value | Default, Min, Max, Speed |
Double | double | RW | A double precision floating point value | Default, Min, Max, Speed |
Integer | int | RW | An integer value | Default, Min, Max, Speed |
Boolean | bool | RW | A boolean value | Default |
String | string | RW | A string value | Default, MaxLines, MinLines |
Enum | string | RW | A string value of type that matches the values of an enumeration. The possible values are define in the field Elements. | Default, Elements |
Color | Color | RW | A color value | Default, Alpha |
Asset | Uri | RW | A general Uri value that addresses one or multiple asset pools | AssetPools |
FloatArray | float[] | RW | An array of float values | Default, MinLength, MaxLength |
DoubleArray | double[] | RW | An array of double values | Default, MinLength, MaxLength |
IntegerArray | float[] | RW | An array of integer values | Default, MinLength, MaxLength |
BooleanArray | bool[] | RW | An array of boolean values | Default, MinLength, MaxLength |
ByteArray | byte[] | RW | An array of byte values | Default, MinLength, MaxLength |
StringArray | string[] | RW | An array of string values | Default, MinLength, MaxLength |
All Data Items are described by meta data that can be edited in the Property Editor after clicking it. For example the Ventuz Director uses them to display Template and Project Data properly for the operator of the program. In Remoting you can use the Data Model's Meta Data to accomplish similar results. Below you can see how Ventuz handles these meta data.
Data Types | Value | Effect |
all | empty string | Not used in the automatic naming. |
!X | Shows the value of this data item in the display name of the page instead of in its description. | |
float, double | fX | Fixed point number with X decimals. X defaults to 2. |
cX | Currency with X decimals. X defaults to 2. | |
eX | Exponential notation with X decimals. X defaults to 6. | |
nX | Number with X decimals. X} defaults to 6. | |
p | Percentage. Note that the displayed number is therefore multiplied by 100. | |
integer | dX | Integer number with minimum X digits. X defaults to 1. |
xX | Hexadecimal number with minimum X digits. X defaults to 1. | |
boolean | X;Y | X if true, else Y. |
string, enumeration | X | Show string truncated to X characters. Do not truncate if 0. |
-X | Show string truncated to X characters and show elipsis for truncated characters. | |
color | c | Known color name or expressed as Red, Green, Blue values. |
# | Hexadecimal string. | |
array | 0 "X" | Show number of values followed by X |
csv | Show values as comma separated list. | |
asset | nx | File name with extension. |
n | File name without extension. | |
uri | Full file path. |
Data Types | Property | Usage |
all | Default | The initial value of the data item. |
float, double, integer | Max | Maximum possible value. Value will be set to Max if it is greater. |
Min | Minimum possible value. Value will be set to Min if it is less. | |
Speed | Change speed when using drag and slide to change the value. | |
string | Choices | You can add a comma seperated list of values to change the text box to a combo box, so that the user can choose from predefined values as well as type a custom text. |
MaxLines | Maximum number of lines. Will be truncated to this number of lines if it is exceeded. | |
MinLines | Minimum number of lines. Will be truncated to this number of lines if it is underrun. | |
RegEx | A regular expression that the given text is tested against so that only input of a certain form is allowed. If it does not match the text cannot be set. | |
color | Alpha | Whether alpha can be defined as well or not. |
enumeration | Elements | Comma separated list of elements that the user can choose from. Note that Default must be present in this list. |
array | MaxLength | Maximum allowed number of values in the array. |
MinLength | Minimum allowed number of values in the array. | |
asset | AssetPools | The allowed asset pool to choose from. All assets that are not associated with any of the chosen pools will be ignored. Misc allows any type of file. This also filters the list of assets in the shotbox of the Ventuz Director when it was opened by clicking on the asset channel. |
Required | If set it disallows to leave this data item empty. |
ventuz://templates
ventuz://templates/
ventuz://templates/<sceneidentity>/Examples:
ventuz://templates/scene1/ ventuz://templates/scene2/ ventuz://templates/folder|scene3/
Please note that the Project Template Host does not have a name! Therefore the first path segment after the base uri is always the name of the Scene Template Host regardless if the scene host is parented in a project host or not!
Two scenes saved as .\Scenes\Folder\Scene1.vzs and .\Scenes\Folder_Scene1.vzs would result in an identical Uri address for their template hosts: ventuz://templates/folder_scene3/. Injecting these two scenes into a project template host will cause an error to be thrown!
ventuz://templates/<sceneidentity>/<AnimationDataItem>/ ventuz://templates/<sceneidentity>/<AnimationDataItem>/<AnimationDataItem>/.../Examples:
ventuz://templates/scene1/Animation1/ ventuz://templates/scene1/DataGroup.Animation.DataItem/ ventuz://templates/folder|scene3/DataGroup.Animation.DataItem/ ventuz://templates/folder|scene3/DataGroup.Animation.DataItem/DataGroup.DataItem/
Two Animations bound to a DataModel as /DataGroup/Animation1 /DataGroup_Animation1 would result in an identical name for their sub template hosts: ventuz://templates/scene1/DataGroup_Animation1/. The Scene Model Validator will cause an error to be thrown!
ventuz://templates/<scene_identity>/Scene ventuz://templates/<scene_identity>/<Animation_DataItem>/<TemplateName>Examples:
ventuz://templates/scene1/Animation1/Template1 ventuz://templates/scene1/Animation1/Template2 ventuz://templates/scene1/Animation1/Animation2/Template3
The Scene Template has always the reserved name "Scene". This name cannot be changed by the user. Other Scene template may be added in the future (Global, Constant, etc
All templates defined in a template host must be unique. If multiple Animation Nodes are grouped all Present States must have a unique name across all animations within that group. Otherwise an error will be thrown.
".group.group.item"
"$DataModelname.group.group.item"
"TemplateName.group.group.item"
Examples:
.Text1 Animation1/Template1.Line1.Text Animation1/Template1.Line1.Color Animation1/Animation2/$Group2.Headline.Text
Ventuz supports three different data formats: XML, JSON and BIN. all of these formats are 100% compatible to each other and the user can decide which format he wants to use. All three formats are text based and the receiver (Ventuz) can easily decide which parser to user. It simply looks to the first non-whitespace character: "<" for XML, "{" for JSON and any other for base64-BIN
The JavaScript Object Notation (JSON.org) has some advantages and disadvantages compared to XML:
<VTD ns="ventuz://templates/ingame/Scene"> <LowerThird_Center ns="ventuz://templates/ingame/LowerThird_Center/NS2LAdd"> <FirstLine>First Line</FirstLine> <FirstAdd>Addon Text</FirstAdd> <SecondLine>Second Line</SecondLine> <Visual01>ventuz://scenes/Assets/logos/FrankfurtSnakes.vzs</Visual01> <Visual02>ventuz://images/Assets/sponsorlogos/HH.png</Visual02> </LowerThird_Center> <UpperThird ns="ventuz://templates/ingame/UpperThird/Scoreboard"> <Banner ns="ventuz://templates/ingame/UpperThird/Scoreboard_Banner/Banner2LAdd"> <FistLine>First Line</FistLine> <FirstAdd>Addon Text</FirstAdd> <SecondLine>Second Line</SecondLine> <Visual>ventuz://scenes/Assets/logos/HP.vzs</Visual> </Banner> </UpperThird> </VTD>
{ "@": "ventuz://templates/ingame/Scene", "LowerThird_Center": { "@": "ventuz://templates/ingame/LowerThird_Center/NS2LAdd", "FirstLine": "First Line", "FirstAdd": "Addon Text", "SecondLine": "Second Line", "Visual01": "ventuz://scenes/Assets/logos/FrankfurtSnakes.vzs", "Visual02": "ventuz://images/Assets/sponsorlogos/HH.png" }, "UpperThird": { "@": "ventuz://templates/ingame/UpperThird/Scoreboard", "Banner": { "@": "ventuz://templates/ingame/UpperThird/Scoreboard_Banner/Banner2LAdd", "FistLine": "First Line", "FirstAdd": "Addon Text", "SecondLine": "Second Line", "Visual": "ventuz://scenes/Assets/logos/HP.vzs" } } }
VlREMSAfdmVudHV6Oi8vdGVtcGxhdGVzL2luZ2FtZS9TY2VuZaARTG93ZXJUaGly ZF9DZW50ZXIgM3ZlbnR1ejovL3RlbXBsYXRlcy9pbmdhbWUvTG93ZXJUaGlyZF9D ZW50ZXIvTlMyTEFkZGEKRmlyc3QgTGluZQlGaXJzdExpbmVhCkFkZG9uIFRleHQI Rmlyc3RBZGRhC1NlY29uZCBMaW5lClNlY29uZExpbmVhMHZlbnR1ejovL3NjZW5l cy9Bc3NldHMvbG9nb3MvRnJhbmtmdXJ0U25ha2VzLnZ6cwhWaXN1YWwwMWEqdmVu dHV6Oi8vaW1hZ2VzL0Fzc2V0cy9zcG9uc29ybG9nb3MvSEgucG5nCFZpc3VhbDAy /6AKVXBwZXJUaGlyZCAvdmVudHV6Oi8vdGVtcGxhdGVzL2luZ2FtZS9VcHBlclRo aXJkL1Njb3JlYm9hcmSgBkJhbm5lciBCdmVudHV6Oi8vdGVtcGxhdGVzL2luZ2Ft ZS9VcHBlclRoaXJkL1Njb3JlYm9hcmRfQmFubmVyL0Jhbm5lcjJMQWRkYQpGaXJz dCBMaW5lCEZpc3RMaW5lYQpBZGRvbiBUZXh0CEZpcnN0QWRkYQtTZWNvbmQgTGlu ZQpTZWNvbmRMaW5lYSN2ZW50dXo6Ly9zY2VuZXMvQXNzZXRzL2xvZ29zL0hQLnZ6 cwZWaXN1YWz/////
Templates can be launched in Designer directly via the Template Data Editor. The editor can be used to inject Template Data directly into the Template Engine. It is also very useful to check the Template Data for a remoting application and the data structure in different datatypes.
The editor can be opened via the small downwards arrow next to the Template, acessed either directly from the Scene or the Scene Data.
On the left side, the data structure in different data types is accessible. You can change the existing one, copy it or paste an own data structure for testing purposes.
On the right side, the interactive editor can edit the Template Data items, with the standard Property Editor. With Activate & Close the Template is launched with the current data structure.
