« Previous: Compositon List
Next: Composition Projector »
Render Setup Objects
Render Setup Objects Provides a list of different elements from the Render setup
Modes
The Render Setup Objects node can provide a list of different elements depending on the mode chosen.
Composition from Config:
  • Provides a full list of Compositions currently used in your active render setup
Composition from Layer:
  • Provides a full list of all Composition layers currently used inside the Designer
Canvas:
  • Provides a full list of all Canvases currently present in the active render setup
Screen:
  • Provides a full list of all Screens currently used in your active render setup
Output:
  • Provides a full list of all Outputs currently configured in your active Device configuration
