Mesh Loader | Loads geometry which has been imported in Ventuz and is stored in the Project folder. |
For a discussion on importing non-vzm files (i.e. FBX, OBJ, COLLADA, glTF, ...) see Importing of 3D Geometry and for a list of supported geometry formats and their characteristics go to Supported Formats.
