The address is as following:
http://IP Address:22404 | Via the Web Browser you can access the Configuration Editor directly by entering the IP of the Ventuz machine and the Port |
http://localhost:22404 | Open the Configuration Editor via your local VMS on your machine |
http://192.168.4.25:22404 | sample address for the Web Configuration Editor on another machine |
