![]() | Blending | This node modifies the blending rules for superposed pixels with industry standard presets |
![]() | Alpha Blending | This node modifies the blending rules for superposed pixels. |
When a fragment has passed all tests (see 3D Mask Nodes , Z-Testing Node, Alpha Testing Node, Stencil Nodes), its color is applied to the render output and overwrites any value previous set by other objects. With alpha blending, the final pixel color can be a combination of both the fragment (source) pixel color and alpha as well as the pixel color and alpha in the render output (destination).
Preset | Color Function | Alpha Function |
Overwrite | SourceColor | SourceAlpha |
Normal | SourceColor + DestinationColor * (1-SourceAlpha) | SourceAlpha + DestinationAlpha * (1-SourceAlpha) |
LinearDodge (Add) | SourceColor + DestinationColor | SourceAlpha + DestinationAlpha * (1-SourceAlpha) |
Screen | (SourceColor + DestinationColor) - (SourceColor * DestinationColor) | SourceAlpha + DestinationAlpha * (1-SourceAlpha) |
Substract Rendering from Background | SourceColor - DestinationColor | SourceAlpha + DestinationAlpha * (1-SourceAlpha) |
Substract Background from Rendering | DestinationColor - SourceColor | SourceAlpha + DestinationAlpha * (1-SourceAlpha) |
Multiply | SourceColor * DestinationColor | SourceAlpha + DestinationAlpha * (1-SourceAlpha) |
Multiply X2 | SourceColor * DestinationColor * 2 | SourceAlpha + DestinationAlpha * (1-SourceAlpha) |
Glow | SourceColor + DestinationColor | DestinationAlpha |
The shaders in Ventuz5 make sure the source color is pre-multiplied with the source alpha. This is why the formula for normal blending does not multiply the SourceColor with SourceAlpha, this has already happened in the shader. The same is true for all other blending modes.
Compared to the Blending Node there are no predefined blending modes here. Instead the Node directly offers the capability of the graphics card for greater flexibility. Both the source and destination color are treated as a 4-dimensional vector (red, green, blue, alpha) which is multiplied with a blend factor before applying the chosen operation.
To recreate the presets from the Blending Node, enable SeparateAlpha and use these settings:
Overwrite | (SourceColor * One) ADD (DestinationColor * Zero) | (SourceAlpha * One) ADD (DestinationAlpha * Zero) |
Normal | (SourceColor * One) ADD (DestinationColor * InverseSourceAlpha) | (SourceAlpha * One) ADD (DestinationAlpha * InverseSourceAlpha) |
LinearDodge (Add) | (SourceColor * One) ADD (DestinationColor * One) | (SourceAlpha * One) ADD (DestinationAlpha * InverseSourceAlpha) |
Screen | (SourceColor * InverseDestinationColor) ADD (DestinationColor * One) | (SourceAlpha * One) ADD (DestinationAlpha * InverseSourceAlpha) |
Substract Rendering from Background | (SourceColor * One) ReverseSubtract (DestinationColor * One) | (SourceAlpha * One) ADD (DestinationAlpha * InverseSourceAlpha) |
Substract Background from Rendering | (SourceColor * One) Subtract (DestinationColor * One) | (SourceAlpha * One) ADD (DestinationAlpha * InverseSourceAlpha) |
Multiply | (SourceColor * DestinationColor) ADD (DestinationColor * Zero) | (SourceAlpha * One) ADD (DestinationAlpha * InverseSourceAlpha) |
Multiply X2 | (SourceColor * DestinationColor) ADD (DestinationColor * SourceColor) | (SourceAlpha * One) ADD (DestinationAlpha * InverseSourceAlpha) |
Glow | (SourceColor * Onw) ADD (DestinationColor * One) | (SourceAlpha * Zero) ADD (DestinationAlpha * One) |
