![]() | Ticker | This node provides the functionality to create advanced tickers, crawls and rolls via the Arrange node. |
![]() | Layout | This node provides the functionality for simple layout via the Arrange node. |
The Ticker and Layout nodes are so called Arrange Controllers that can be bound to the Control property of an Arrange node. They override and extend the Arrange nodes default behavior in how child nodes are positioned, oriented and so on to fit a variable amount of data to a limited amount of space.
The Ticker node in turn inserts each child at one end of the ticker area, moves it across and removes it again once it has left the area. As soon as one child has completely entered the ticker area, the next one is inserted behind the previous one to create a constant stream of information. The Layout node arranges items horizontally up to the layout width and then creates a line break to position excessive items in the next line.
Both Controllers have a DataMode property to enable the dynamic data driver mode. As long DataMode is None the Data property is ignored.
The Layout node in Non-DataMode arranges items automatically based on their size and content. This is very useful for text blocks or images embedded in text. Paragraphs could be separated in several single text elements which are layouted automatically. Changing the size of any element of the layout will re-arrange them immediately. This makes the Layout node very interesting for text elements containing dynamic images (smileys, logos, etc).
The Ticker in Non-DataMode can be used to scroll elements through a visible area that is not large enough to fit them at the same time. Invisible elements are automatically blocked and therefore not rendered which saves rendering performance. In addition, changing the order or number of elements becomes easier compared to having manually positioned the elements via Axis nodes.
If the total width of all elements chained together including the ChainOffsets does not fill the requested Width the Ticker can behave strangely and elements pop in inside the visible range. So always provide enough elements to fill the entire range!
Use a stencil mask to clip rendering of the ticker content to the width of the ticker. This will stop elements suddenly appearing and disappearing on their entire length once they hit one of the boundaries of the ticker area.
Elements are always rendered in the order they appear in the hierarchy. For some tickers (i.e. depth-ticker) the order has to be adjusted to maintain transparencies. The Sort property enables the position based sorting.
To make this work, the string passed to Data has to be formatted by an XML-like markup. Only XML elements and attributes are used, all other XML markup - including the values (text) of elements - is ignored. When a new piece of information is to be shown, the Arrange Controller will look for a direct child whose name matches the name of the XML element. On this node, it checks for properties which matches the name of one of the XML attributes and assigns the corresponding value.
In general, one would use a Hierarchy Container, assign it a name and expose properties to be addressed by the Arrange Controller. For example, an element for displaying a stock quote in a crawl could expose properties such as Name, LastTrade and Change. The internal logic of that quote container could manage the display of a colored arrow for positive and negative Change values. The container itself could simply be named "QUOTE". Setting Data to
Attribute values are always parsed using the Invariant Culture (en-us) to be converted to the type of the target property. String values have to be HTML encoded in order to contain special characters such as < or >. Use < and > instead.
<QUOTE Name="MSFT" LastTrade="123.25" Change="4.125"/> <QUOTE Name="AAPL" LastTrade="67.75" Change="2.125"/> <SPONSOR Image="MySponsor.jpg"/>
The ticker has some reserved element and attribute names to control the ticker. It also provides two methods (Continue and Reset) and a few output properties and events to control the data feed or other logic.
Method | Reset | Clears the entire queue and removes all visible elements. The Empty flag will be raised. |
Input | Threshold | If the QueuedItems output property runs below the specified value, the Underrun event is fired. |
Output | Empty | Indicates if the queue is empty. An empty ticker does not fire Underrun events! Use this flag to start a new ticker from its empty state. |
Output | QueuedItems | Number of items in the queue. If this value is runs below the Threshold value the Underrun event is fired. |
Event | Underrun | Fired if the QueuedItems changes and its value is below the Threshold. Empty queues does not fire this event - they raise the Empty flag instead! |
The PAUSE reserved element name is used to pause the Ticker. Optional attributes controls additional parameter for it.
Examples:
<PAUSE/> <pause duration="1.0"/> <pause duration="2.0" m="center"/> <Pause D="1.5" M="c"/>
<FILL/> <QUOTE Name="MSFT" LastTrade="123.25" Change="4.125"/> <QUOTE Name="AAPL" LastTrade="67.75" Change="2.125"/> <SPONSOR Image="MySponsor.jpg"/>
TickerIn | Called if the element moves into the visible area |
TickerFirstIn | Called if the element is the very first element moves into the visible area. |
TickerOut | Called if the element moves out of the visible area. |
TickerLastOut | Called if the container is the last element moved out of the visible area. |
Sometimes it is necessary to adjust the spacing between elements within a Ticker. The ChainOffset property of the Arrange node is a constant offset inserted between all elements. If an individual spacing is required, a Volume node can do that task. The node could be used directly or inside a container. It renders no graphics but defines a size (or a volume) which is honored by the Ticker node. The size could be adjusted as a property in the XML data.
