Broadcast Video Output
The Broadcast Video Output settings are only available in the Ventuz Broadcast Edition. They configure the video format of input and output signals as well as key processing and rendering quality. Additional hardware specific settings are also available.
Hardware
Video Board
Ventuz currently support 4 different types of SDI video boards. All boards have their pros and cons - especially in pricing and quality. All Vendors provide differently featured versions of their products. Please contact your Ventuz Integrator for details.
Vendor Boards Inputs Outputs Remarks
 Deltacast Delta-sdi
Delta-hd
2 1 Fill+Key
 DVS Centaurus II 2 1 Fill+Key
 Blackmagic Decklink Series - 1 Fill+Key Decklink boards can only operate as an output or input board. Not as both simultaneously!
 Matrox X.mio 2 1 Fill+Key This board is used for  Miranda X-3D and X-Ventuz only.
Video inputs provided by the selected video hardware are always inserted before the system enumerated device list referenced by the Video In page of the Machine Configuration.
Deltacast
The Deltacast sd and hd sdi boards have been designed for real-time video IO in television broadcast. They provide precisely the feature set required for reliable SDI IO and VANC processing. Neither more, nor less. The Deltacast product range is the official Ventuz recommendation. Please contact Ventuz sales or your Ventuz Broadcast Integrator for details.
Additional options for Deltacast boards:
Blackmagic
Blackmagic Design provides several (cheap) solutions for SDI output (Fill+Key). The boards have been designed for connecting a tape deck to a PC for recording and playback to tape. Therefore, the product name is Decklink and the boards can either output or input SDI signals - but not both.
Some of the Decklink boards have an internal keyer hardware onboard which make them a cost effective solution for downstream applications. Please note that Decklink boards do not provide any watchdog or power-fail options!
Additional options for Blackmagic boards:
If the used board provides an analog (monitoring) output these options allows to configure it.
DVS
The DVS Centaurus II board has been designed for very reliable and stable video IO between the SDI and PC worlds. It provides post-production formats such as 1080p@60 or 2k. In television broadcast these formats are usually not used and thus are not supported by Ventuz. The board comes with an optional keyer and is a reliable selection for both up-stream and down-stream applications.
Matrox
The Matrox x.mio board has been designed as a video toaster and for professional SDI IO for PC's.  Miranda Technologies uses this board for their Ventuz based products X-3D and X-Ventuz. For internal key mode, the x.mio Compositor option must be enabled!
Buffers
This value defines the number of frame buffers used to output the graphics to SDI. The lowest value depends on the SDI hardware used. Usually this lowest value should be used. Higher values increase the general output delay, but also decrease the risk of frame drops. Crawl or roll application, for example, often use a higher number of buffers because the output delay is not an issue. Higher values also increase the video input to video output delay, therefore applications needing a short input-to-output-delay should keep this value as low as possible.
Threaded DMA
Some boards provide this option to enable a different mode of data transfer between video board and GPU. Depending on the type and content of the graphics the Threaded DMA may improve rendering performance. Trying both modes is recommended if the graphics load is approaching the limits of the real-time capabilities of the machine.
More
Some video boards have additional options. Press the More button to configure.
Video Format
Ventuz supports a list of standard video formats used in the professional TV broadcast market. Even if some boards support many more SDI standards, Ventuz does not support them as long as they are not used in TV broadcast. Additionally, some formats are not supported by certain video boards.
As soon as a video board has been selected, this list will only show formats supported by the selected hardware.
Name Rate Frame Mode Frame Size Pixel Aspect
SD PAL
SD PAL 50.00 interlaced 720x576 16/15
SD PAL 16:9 50.00 interlaced 720x576 64/45
SD NTSC
SD NTSC 59.94 interlaced 720x486 9/10
SD NTSC 16:9 59.94 interlaced 720x486 6/5
HD 720p
HD 720p 50.00 progressive 1280x720 1/1
HD 720p 59.94 progressive 1280x720 1/1
HD 720p 60.00 progressive 1280x720 1/1
HD 1080i
HD 1080i 50.00 interlaced 1920x1080 1/1
HD 1080i 59.94 interlaced 1920x1080 1/1
HD 1080i 60.00 interlaced 1920x1080 1/1
HD 1080p
HD 1080p 25.00 progressive 1920x1080 1/1
HD 1080p 29.97 progressive 1920x1080 1/1
HD 1080p 30.00 progressive 1920x1080 1/1
Preview
Enabling the Preview will render the actual video output to a window on screen. This window is necessary to send interactive commands such as mouse and Windows MultiTouch events to the renderer. If the Preview is disabled, only keyboard inputs will be accepted.
The Preview is not a preview in the sense of previewing the next graphical element that is going to appear on-air. It is only an additional output of the signal sent to the SDI board.
The Preview window is not synchronized to the actual SDI board. The SDI board has its own timing hardware. The graphics here are not synchronized to the SDI board. Animation or videos may stutter, because they are synchronized to the SDI output - not to the graphics board (and thus the preview window). Also  tearing effects may appear.
Interlaced video formats are displayed progressive: a 1080@25i format will be display as it would be a 1080@50p format, because Ventuz always renders progressive frames internally.
3D Stereo
Ventuz supports 3D stereoscopic graphics. In order to render a stereo view of a 3D scene, the scene needs to be rendered twice: left and right eye view. The parameters for the two eyes are called Eye Distance and Frustum Shift. Ventuz does not make any correlation of the internal coordinate system to any real-world units, therefore there are no default or recommended values for these two parameters. The Eye Distance is understood as the distance between the two eyes (or lenses) looking into the 3D world. The Frustum Shift is a correction value to line up the two 3D perspective frustums again. The two values can be manually adjusted in the Broadcast Live Config which is accessible in the Render Window of Ventuz Designer and Ventuz Runtime.
The dual-channel mode is currently only supported on Deltacast boards.
Two boards are required in external or internal key mode!
Genlock
The  genlock configuration defines which source is used to synchronize the video output. The availability of  genlock source depends on the used hardware and its feature set. Some  genlock sources allow for a constant delay to adjust the phase of the outgoing signals. The two values H and V define that delay in pixels (clocks) and lines. Some boards also provide the ability of a negative delay, but usually these values are positive.
Key Processing
Multisampling
Select the quality of  multisampling used to render a scene.
Select None multisampling for scenes consisting of texture and texture based fonts only or if the displayed graphics is a 2D design. Multisampling would not improve the quality but it will lower the rendering performance!
