Ventuz Machine Service
How to connect
VMS runs as a multi-client TCP server on port 19401. The actual communication protocol is text based (UTF-8) and accepts simple human readable commands. A user can use a telnet client like Putty or Microsoft Telnet Client to connect to VMS.
Configure Windows Service
Disable VMS
Configure IP Restrictions
Process Modes
SYSTEM USER
<none> <none> -app -notify
No VMS is running Service Application Application Notification
VMS Service is running exit 2 Notification Notification Notification
VMS Application is running exit 2exit 1exit 1exit 1
VMS Notification is running Serviceexit 1exit 1exit 1
Notification Icon
Error xxxx0000 No connection to Ventuz Runtime or Designer
Warning 0000xxxx Connection Ventuz Runtime or Designer, but no renderer/project loaded
Ok 00000000 Ventuz is up and running.
VMS Service is not running. No connection from VMS notification to VMS service.
Project Management
IP Filter / Access Restrictions
VMS Machine Discovery
route print
This Microsoft support page explains how to change the metric of network adapters.
VMS Command Summary
HELP
HELO
HELO
250 Completed [104]
VZ_108290380002111_BFEBFBFF000106A5_00426-065-0527052-86603 Hello [192.168.3.140:50613]
STATE
STATE
211 Status [37]
Error [00040000]: ErrorDisconnected
INFO
INFO
200 Ok [636]
<VentuzInfo>
  <Version />
  <MachineName>LOCAL(VBOX-DOC2013)</MachineName>
  <Mode>Designer</Mode>
  <EditionName>Ventuz 4 V4.00.00 x64</EditionName>
  <GroupID>0</GroupID>
  <MachineID>0</MachineID>
  <RateNum>60000</RateNum>
  <RateDen>1000</RateDen>
  <PipeModes>
    <PipeMode>OffScreen</PipeMode>
  </PipeModes>
  <ProcessID>1292</ProcessID>
  <ProcessGUID>a6cd8d0d-c2d3-4d88-b1ef-54cb3593df75</ProcessGUID>
  <SystemID>VZ_108290380002111_BFEBFBFF000106A5_00426-065-0527052-86603</SystemID>
  <ProjectGUID>15e6698c-7726-4be1-9ede-3ee1c58d9005</ProjectGUID>
  <ProjectName>Hockey</ProjectName>
</VentuzInfo>
ID
ID
200 Ok [20]
VBOX-DOC2013, 0, 0
ID NEW-NAME 1 2
200 Ok [17]
ID has been set
ID
200 Ok [16]
NEW-NAME, 1, 2
GETCFG / SETCFG
GETCFG
200 Ok [130]
<VMS>
  <ProjectPath>C:\Users\Public\Documents\Ventuz4\Projects</ProjectPath>
  <ProjectPath>G:\PROJECTS</ProjectPath>
</VMS>
Use SETCFG by specifying the number of expected bytes followed by the xml to be set:
SETCFG 61
<VMS>
<ProjectPath>D:\Projects\Ventuzz</ProjectPath>
</VMS>
250 Completed [28]
Configuration has been set
CLOCK
CLOCK
250 Completed [7]
23470
KILL / KILLALL
INST
INST
200 Ok [390]
<Installations>
  <Installation Version="4.00.00" Build="181">
    <InstallationDir>C:\Program Files\Ventuz Technology Group\Ventuz 4\</InstallationDir>
    <DesignerPath>C:\Program Files\Ventuz Technology Group\Ventuz 4\Ventuz.exe</DesignerPath>
    <RuntimePath>C:\Program Files\Ventuz Technology Group\Ventuz 4\VentuzPresenter.exe</RuntimePath>
  </Installation>
</Installations>
SCAN / SCANSTATE
SCAN
200 Ok [18]
Scan started ...
SCANSTATE
250 Completed [16]
Scan completed
PROJ
PROJ
200 Ok [44129]
<Projects>
  <Project VPR="false" ID="96077cdf-573b-4f5e-8869-5dcb6e1c4768" FullPath="C:\Users\Public\Documents\Ventuz4\Projects\__HELP__\VentuzHelp\Help1.vzp">
    <VentuzVersion>4.0.0.0</VentuzVersion>
    <Name>Help1</Name>
    <Author>Ventuz</Author>
    <Copyright>2013 Ventuz Technology</Copyright>
    <Category>Ventuz</Category>
    <ThumbnailBase64>iVBORw0KGgoAAAA..........ggg==</ThumbnailBase64>
  </Project>
</Projects>
SCENES
scenes 15e6698c-7726-4be1-9ede-3ee1c58d9005
200 Ok [216]
Templates/FS_LineUp, Templates/FS_Promo, Templates/FS_Scoreboard, Templates/InGame
SM
SM 15e6698c-7726-4be1-9ede-3ee1c58d9005 Templates/FS_Promo
200 Ok [44778]
<SceneModel DisplayName="templates/fs_promo" ThumbnailArea="0,0,1,1" Thumbnail="iVBORw0KGgoA........JRU5ErkJggg==" xmlns="http://www.ventuz.com/Ventuz/SceneModel/1.0">
  <SceneModel.DataModel>
    <DataModel>
      <Animation AnimationName="FS_Promo" Name="FS_Promo" Label="Control" />
    </DataModel>
  </SceneModel.DataModel>
  <SceneModel.DataModelScene>
    <DataModel>
    </DataModel>
  </SceneModel.DataModelScene>
  <SceneModel.Animations>
    <AnimationModel Name="FS_Promo">
      <AnimationModel.DataModel>
        <DataModel>
          <String Default="7:30" MinLines="1" MaxLines="1" RegEx="" Name="Time" Label="Time" Description="Event start time." Mode="RW" />
          <String Default="VHL NIGHT" MinLines="1" MaxLines="1" Name="Title" Label="Event" Description="Event title" Mode="RW" />
          <String Default="LIVE" MinLines="1" MaxLines="1" Name="FirstLine" Label="FirstLine" Description="FirstLine" Mode="RW" />
          <String Default="Event Location" MinLines="1" MaxLines="1" Name="SecondLine" Label="SecondLine" Description="SecondLine" Mode="RW" />
          <String Default="City" MinLines="1" MaxLines="1" Name="ThirdLine" Label="ThirdLine" Description="ThirdLine" Mode="RW" />
          <String Default="NIGHT" MinLines="1" MaxLines="1" Name="LogoSubtitle" Label="3D league subtitle" Description="3D subtitle below the league logo" Mode="RW" />
          <Visual Images="True" Textures="True" Movies="True" Scenes="True" Required="True" Name="Visual01" Label="Left_TeamVisual" Description="The left team visual commonly used for the home team logo." Mode="RW" />
          <Visual Images="True" Textures="True" Movies="True" Scenes="True" Required="True" Name="Visual02" Label="Right_TeamVisual" Description="The rightt team visual commonly used for the guest team logo." Mode="RW" />
          <Visual Images="True" Textures="True" Movies="True" Name="Visual" Label="BGD_Still" Description="Background image" Mode="RW" />
        </DataModel>
      </AnimationModel.DataModel>
</SceneModel>
START
START 15e6698c-7726-4be1-9ede-3ee1c58d9005
200 Ok [23]
Process started [680]
HW
The HW command gives detailed information about available hardware, available licenses and installed cultures on the VMS system. The returned XML document is used by the Ventuz Configuration tools to remotely configure the system. The hardware information also contains details about the screen screen configuration of the graphics adapter. (Eyefinity or Mosaic configuration)
HW
200 Ok [60438]
<MachineHardware>
  <License>
    <Outputs>2</Outputs>
    <OutputsSDI>2</OutputsSDI>
    <OutputsIVGA>2</OutputsIVGA>
    <Cluster>true</Cluster>
    <Misc />
    <OffscreenOnly>true</OffscreenOnly>
  </License>
  <Gamepads />
  <SerialCOMs />
  <MidiInputs>
    <Device Name="LoopBe Internal MIDI" />
  </MidiInputs>
  <MidiOutputs>
    <Device Name="Microsoft GS Wavetable Synth" />
  </MidiOutputs>
  <BoardsBinarySource>Enum</BoardsBinarySource>
  <BoardsBinary>PDw8 ...
  <Adapters>
    <Adapter Ordinal="0" Vendor="NVidia" GpuCount="1" Width="1920" Height="1080">
      <Output X="0" Y="0" W="1920" H="1080" />
    </Adapter>
    <Adapter Ordinal="1" Vendor="NVidia" GpuCount="1" Width="1920" Height="1080">
    </Adapter>
  </Adapters>
</MachineHardware>
OPT
OPT
200 Ok [1664]
    <Integer Min="0" Max="2147483647" Name="ID" Label="ID" Mode="RW" />
    <Enum Elements="&lt;None&gt;, Videowall" Name="RenderSetup" Label="Render Setup" Mode="RW" />
  </Group>
    <Boolean Name="Wireframe" Label="Wireframe" Mode="RW" />
    <Boolean Name="Stats" Label="Show Statistics" Mode="RW" />
    <Boolean Name="InputDiag" Label="Show Input Diagnostics" Mode="RW" />
    <Boolean Name="BoundingBoxes" Label="Show Bounding Boxes" Mode="RW" />
    <Boolean Name="Alpha" Label="Show Alpha/Key" Mode="RW" />
  </Group>
      <Integer Default="0" Min="0" Max="10000000" Name="SoftwareWatchdogTimeout" Label="Software Watchdog Timeout" Mode="RW" />
      <Boolean Default="False" Name="LogVideoEngineState" Label="Log Video Engine State" Mode="RW" />
    </Group>
      <Group Name="SSF_OUT_0" Label="Shared Surface">
        <Enum Elements="None, Low, Medium, Best" Name="Multisampling" Label="Multisampling" Mode="RW" />
        <Color Default="127, 0, 0, 32" Alpha="True" Name="BorderColor" Label="Border Color" Mode="RW" />
        <Boolean Default="True" Name="KeyPremultipled" Label="Additive Key" Mode="RW" />
      </Group>
    </Group>
  </Group>
</DataModel>
OPT .REN.Wireframe
200 Ok [7]
False
OPT .REN.Wireframe True
200 Ok [6]
True
LST / ACT / GET / SET / DEL / REN
EXIT
