The performance statistics is a display rendered above the Ventuz output. It can be enabled from the designer or the live options to analyze performance problems in a scene.
This has been enhanced as of Ventuz 4.04.00.
The performance statistics contain a lot of information. In many cases displaying it all can be a bit overwhelming and requires a lot of screen real-estate. So individual sections can be enabled and disabled:
With all sections enabled, it can looks like this:
Here is an explanation of these sections. This is done with the drop-down button.
In general:
To see spikes in performance better, enable the History Mode with the drop-down box. Pressing the pause key on keyboard will pause and continue the update of the bars. When the history mode is on and pause mode is on, use the page-up and page-down keys to scroll.
For instance, the driver may need to round up the width of a texture to the next power of two, so a 640 pixel wide texture gets rounded to 1024, a substantial difference. Ventuz can not know this and reports the incorrect amount.
The states mean:
The states are:
The buffers show how many buffers Ventuz has allocated and how many frames in the future are available. If these buffers run dry, increase the number of buffers for that movie.
The console will work like a normal log file where messages printed will scroll endlessly.
This is useful to capture events and state changes.
The text-color can be changed with [tc:rgb] and [tc:rrggbb], where r, g and b must be replaced by web-style hex-colors. [tc:ff0000] would be red.
public static Ventuz.Kernel.Tools.PerfMon.Token Script1 = new Ventuz.Kernel.Tools.PerfMon.Token("Script1", 0xff8000);
using(Script1.MeasureCpu) { System.Threading.Thread.Sleep(3); }
Here is a complete example:
using System; using Ventuz.Kernel; using Ventuz.Kernel.Tools; public class Script : ScriptBase, System.IDisposable { private bool changed; public Script() { } public virtual void Dispose() { } // Token for Performance Timing public static PerfMon.Token Script1 = new PerfMon.Token("Script1", 0xff8000); public override void Validate() { changed = true; // Logging that will be overwritten every frame PerfMon.PrintFrame("Hello World\n"); // Logging that will spam the console PerfMon.PrintConsole("LogLogLog\n"); // wait a few milliseconds, and add a bar to timing using(Script1.MeasureCpu) { System.Threading.Thread.Sleep(3); } } public bool OnEnable(int arg) { Ventuz.Kernel.Tools.PerfMon.ConsoleLogEnabled = true; Ventuz.Kernel.Tools.PerfMon.FrameLogEnabled = true; return false; } public bool OnDisable(int arg) { Ventuz.Kernel.Tools.PerfMon.ConsoleLogEnabled = false; Ventuz.Kernel.Tools.PerfMon.FrameLogEnabled = false; return false; } public override bool Generate() { if (changed) { changed = false; return true; } return false; } }
So for shortest delays:
Red(ish): Validation
Green(ish): Rendering
Blue(ish): Idle
Video Process:
Other
