![]() | Identity | This node creates an identity matrix. |
![]() | Zero | This node creates a matrix containing only zeros. |
![]() | Manual | This node provides a matrix where every element can be set manually. |
![]() | Rotation XYZ | This node provides a matrix to rotate around the X, Y or Z axis. |
![]() | Scaling | This node provides a matrix to scale along the X, Y and Z axis. |
![]() | Translation | This node provides a matrix to translate along the X, Y and Z axis. |
![]() | Matrix Switch | This node switches between one of eight input matrices and passes it to the output. |
![]() | Matrix Morph | This node interpolates linearly between two input matrices. |
![]() | Matrix Operation | This node multiplies, divides, add or subtracts two or more 4x4 matrices. |
![]() | Vector Transform | This node transforms a vector (X,Y,Z,W) by a 4x4 matrix and optionally de-homogenizes the result. |
The Matrix Nodes provide special types of matrices that can be used as Input Properties for the World Transformation, View and Projection Nodes.
The Matrix Operation node is usually used to multiply matrices and thus perform a concatenation of matrix transformations. It can, however, also perform element-wise division, addition or subtraction.
